: Speaker Fit Guide Please Check & Ask Fitment ?s HERE ONLY!!!
CadillacSTS42005
07-29-08, 12:07 AM
Fit Guide
NOTE More Years and Models will be added as I have time and chance to verify all the sizes listed below I myself have verified and fully trust.
Eldorado
1992-2002
Front Door Bose 4 Inch Non Bose 5.25 with 2 inch tweeter
Rear 6x9
Seville
1992-1997
Rear 6x9
1998-2004
Dash 3.5
Front Doors Bose 8 Non Bose 6.5
Rear Doors 6.5
Sub 12.5
Deville
1994-1999
*speakers may not be located in all locations but the holes and mounts are there*
*Center Channel 4x6 *
Front Doors 5.25
Front Door Panel 2 Inch
*Rear Door 5.25*
*Rear Door Panel 2 Inch*
Rear Self 6x9
2000-2005
Center Channel 3.5
A Pillars 2 inch
Front Doors 6.5
Rear Doors 6.5
Sub 10
neverstuck
08-07-08, 03:53 PM
hey there master of all that is audio...I just wanted to know ..on the 96-02 eldo if Im pulling the bose speakers ,and the non bose was a 5.25 is there something I shoul;d know about putting 5.25 in the door like a spacer or something ...?thanks for all help past present and probably future
CadillacSTS42005
08-07-08, 04:40 PM
theres a bracket that was used instead of the bose box
any pick a part with a non bose eldo should havem still
SuperC
08-08-08, 12:49 AM
I cannot speak for years after 2000 DTS, or DHS, but a 2000 Base Deville is a 5.25 Midrange speaker. Just replaced mine.
-C
neverstuck
08-08-08, 01:49 PM
thanx again
K_cin_az
08-20-08, 03:50 PM
if I want to replace the factory speakers in the non-bose eldo, it as simple as buying new speakers and installing them? Are they traditional mounts, etc. Just want to make sure there is nothing custom about the way the factor speakers are installed...
CadillacSTS42005
08-20-08, 10:45 PM
correct
nothing special at all
will bolt right in
best buy sells speaker plug connectors which will plug into the stock speaker clip and give you a + and - speaker terminal
K_cin_az
08-21-08, 03:14 PM
cool, I actually was working on my caddy yesterday and seen that it seems like a standard port for 6x9s. To install them though I need to take out the back seats correct? I ran the amp to power them at least so right now I have the factory ones powered..haha, obviously dont sound too good so need to put some new ones in.
CadillacSTS42005
08-21-08, 10:42 PM
correct
prais216
08-27-08, 12:47 PM
Hey guys,
I am new to the group and will have more questions I am sure...I am already learning a lot here!...but for now, can you tell me if I can easily upgrade a 1996 Sedan Deville stock system to a Bose system? I have a '96 Deville that I am selling to my brother in law...I just bought another 96 Deville for a good deal. The "new" car is in better mechanical shape. The only problem is the one I'm selling has the better trim (soft-top, heated seats, and the BOSE system with12 disc changer)...I have a new after-market head unit with DVD and only want to swap the Bose amps and speakers if I can...if not I will have to shell out $$$ for a new system. Are all of the 96 Devilles prewired for the premium sound? Can I easily just remove and install the Bose speakers and the amp in my "new" Deville? Please let know....Again Thank you in advance!!!
STS2003 I am too new to PM you so I've posted this on three threads so far...hope to hear from you soon!
fischman
08-29-08, 10:10 AM
Question about 2003 Cadillac CTS non Bose:
I know that it has a 5 1/4", can an adapter be had to upgrade to the 6 3/4" size of the bose system. I don't want the bose speaker, just to be able to fit a 6 3/4" speaker. Thanks!
Josh F
CadillacSTS42005
08-30-08, 01:07 AM
have to have a custom spacer plate built
Witt
10-20-08, 04:44 PM
I just bought a 2000 Deville DHS (has Bose) and I noticed in the 4 hours I drove in it on Saturday that the Bose system doesn't have the kinda bass response I've gotten used to get in my VW Touareg (Monsoon-kinda stereo)....and I was wondering what I could do to change that..without putting in a sub and all that. (I've done that plenty in the past..not looking to again)
I see the speaker size is said to be 6.5 at the start of this thread..but then on Crutchfield and on this same thread I see 5.25 mentioned. Per Crutchfield, a 6.5 can't fit in this spot. I'm not looking for modifications....so what is the deal? (confused)
Another question....if I buy after market speakers, how many watts per channel (on the Bose) is it powering..RMS? (I'd rather not have to buy an amp and all that if I can just replace the 5.25? speakers in my front and rear door with something better like JBL, Alpine, etc.
This spacer that got brought up....how much extra does that cost on install? If it's just something simple, I'd be open to it....if something costly..probably not. I paid $6000 (119k miles) for this vehicle and I'm not looking to make it a $$ pit.
Thanks for any thoughts or feedback.
-new member Witt
CadillacSTS42005
10-20-08, 04:53 PM
if you want some more low end without a huge cost look into the infinity bass link
its a small self enclosed powered sub which will probably be just what your looking for...
Witt
10-20-08, 05:17 PM
I know about the bass-link, but I'd rather not go the sub route..etc. Any thoughts about the speakers..sizes..?
Thanks.
CadillacSTS42005
10-20-08, 08:41 PM
you want more low end
so youll replace your speakers....
speakers are not powerful enough nor designed to highly increase low end
if you want more bass youll need to add subs its that simple
especially since the stock amp will cut base at higher volume levels like its supposed to..
Witt
10-21-08, 11:36 AM
As mentioned previously, I've had subs before (in 3 other vehicles)..I understand how bass works..lol.
I'm not looking to go the subs route as it's a pain, takes up space, and easily more $$.
Maybe I didn't ask this right....has anyone out there replaced the stock speakers in the front..and had good luck getting some better bass response in doing so? If so, which model of speakers, etc. (You can get better bass response without needing to add a sub)
I'm not looking to have a speaker on wheels....I'm just looking to upgrade the factory speakers..and trying to get a better understanding of how many watts per channel the bose system is putting out..
CadillacSTS42005
10-21-08, 10:13 PM
bose runs 1 ohm
any drop in speaker you replace it with will cut the power sent to it in half
so back to square one
replace the stock sub with a kicker free air one?
Witt
10-22-08, 11:53 AM
STS,
Iíll amuse this idea just to see where it takes me. The ďfactory subĒ in the vehicle, where is it located..I ask because I havenít run across it yet. I assume it to be on the rear deck of the vehicle firing into the back window area. Surely itís a tiny space, and obviously since Iím hearing poor bass with the system itself, itís nearly going unnoticed. That said, what would be your exact recommendation for replacing that item..without modification? (Iím aware the Infinity unit has a built in amp..self powered..but I assume that it wont fit this application)
Back to the speakersÖ.they suck. If I get some JBLs, Alpine, Infinity, etcÖ.will the existing Bose amp(s) be ok to power those to improve sound? Iím not needing to be blasted out, Iím merely wondering if the Bose amplification would be enough to even provide weak power to after-market speakers? (Iím not looking to have new amps and all that)
Thanks.
CadillacSTS42005
10-22-08, 10:46 PM
dead center in the rear deck
its a 10 inch free air sub
2 ohm
75-125 watts stock i believe
will the stock amp power them
sure
but its a 275 watt amp
figure 75 for the sub
thats 200 watts per channel at 1 ohm
so 50 watts per channel at 1 ohm
hook up a JL speak thats 4 ohms now your only using 12.5 watts
hook up a Infinity Kappa 2 ohm and now your only using 50 watts
and no one makes a 1 ohm speak other than bose.
Witt
10-23-08, 03:39 PM
STS....since I cant post a link (new member), I will mention the Kicker 10" free air $89 on Crutchfield....I would see this as a decent, cheap, replacement....and the factory power would be ample....(per your post I assume..)
Thanks for the detail....loved it.
CadillacSTS42005
10-23-08, 06:05 PM
not a problem
thats a good bang for buck sub nothing earth shattering but an improvement over stock without getting crazy
id recommend adding an external amp which has speaker level inputs to power it
connect the stock sub wiring to the speaker level inputs
then power the sub with the amp
powering the amp is cake since the battery is under the rear seat so no need to run amp wires the length of your car.
9BlackN*Black6
11-21-08, 01:08 AM
Whats up everone havent posted in 4ever! Getting the stuff to do a major audio upgrade. Just got a Rockford Fosgate Type RF X7 1500w. Ive heard from many RF fans that the birth sheets on these babies ranged from 1700-1900wrms! I wanted to test it out when I first got it, so I took a trip to my bro's house. He's got a bd1000 pushin' 2 S12L7 solobarics w/ a box as big as his little chevy malibu will fit. We tested the amp for about 1/2 hour on his 12's, adjusting the gain up then down adding a little more bass boost via bass knob, never did turn them both all the way up, as he was a little scared to, but I dont blame him. It made his radar detector drop right off the windshield, was kinda funny. Its a mean amp:want:.
But anyways, Im planning on getting 1 S15L7 4 ohm and a 2 farad cap. Gonna build my own vented box out of 1" MDF. Was gonna get a 10" solo-x but my jaw dropped after I figure the price of the sub and box. I also plan on taking all the carpet out and dynomating the entire trunk, then put it back together so it still looks good. Now I know the stock radio is not gonna be able to overpower the bass but I freakin love the finger controls on the steering wheel.
And this is were I need your help Jason! What head unit will match the controls on the wheel? Also, what kinda interior speaks you suggest?
Thanks man,
Greg
CadillacSTS42005
11-21-08, 10:09 AM
none will work
you must buy an adapter to make them work specific to the hu you buy
9BlackN*Black6
11-21-08, 11:10 AM
none will work
Any idea were do to get the adapter? HU manufacturer or Cadillac? Ever seen anyone successful with keeping the finger controls? Think a bose out of an ETC would be enough juice to not get overpowered/drounded out? Ive never heard one out of an ETC but you obviously would know.
Thanks
Greg
CadillacSTS42005
11-21-08, 11:43 AM
pac makes them
9BlackN*Black6
02-23-09, 02:17 AM
Ok i know i was gonna go small and just get a solo l7 15", but it 09' im takin whats mine, just got a 12" solo x. Yea i know...wow what is he thinking, but my 10" kicker comps can only take so much from my 'source'-(1700w @2 ohms) is alot even at half gain on 10's. Got a 4 Farad Kole Audio Cap few days ago, 150a breaker installed ready for the box build. Get ready for some pics its gonna be bad! My first box build....
tjlwolf
04-01-09, 09:06 PM
not a problem
Thanks for all your help with all this. I blew my sub and now that i have it out i see where it has come unsealed around half the speaker. Probably age, Texas heat and I was listening to the Muse when i blew it!
I just want what i had. No amps, nothing...SO I cant just go buy any ol sub?
What are the specs i need?
Ohms? Watts? Free Air?
Can someone please suggest me a replacement?
I want something cheap and compa:confused:rible to what I have.
ThumperPup
04-01-09, 11:19 PM
was wondering in the 2000 seville looks like there are 3 speakers in the front dash
the once on the outside of tweeters right ?
what abou tthe one in the midle or is that not a speaker ?
ThumperPup
04-02-09, 11:26 AM
[QUOTE=CadillacSTS2003;1591216]Fit Guide
Eldorado
1992-2002
Rear 6x9
1998-2004
Dash 3.5
Rear Doors 6.5
Sub 12.5
I was wondering i have the Bose system in the 2000 seville but i went to look at a fitmant guide and i cant find anything and i also cant find any 8 inch speakers at all are you sure you have the right size for the bose sytem
modboyz
04-04-09, 02:56 PM
Have an '88 Eldorado. Right front door speaker is blown. Non-Bose system (Symphony Sound w/ EQ and Cassette)
What is replacement size?
Thanks
Eric
CadillacSTS42005
04-12-09, 10:56 AM
4.5 inch speaker resides in there pretty darn sure
you need to get a 4 inch speaker and use some fill to take care of the gaps
or on ebay there is someone who sells an adapter plate to fit the 4.5 hole to make it a 4 inch hole
modboyz
04-13-09, 12:38 PM
Thanks
Found one on Ebay from an 88 Seville. I assume it will fit the Eldorado.
derone
04-14-09, 09:25 AM
My '00 STS w/nav has 3 bose speakers in the dash. Any idea's on their size and possible cross references to other GM vehicles for the outer two tweeters.
MisterBlue
08-14-09, 06:35 PM
To get more effective bass from your Bose system, set the bass all the way up, set the midrange all the way down, and then set the treble up about halfway and crank up the volume. :thumbsup:
defflepp1
09-13-09, 08:56 PM
hey i had a few questions about my cadillac. its a 1991 deville and first i dont know how to determine if it has the bose system or not, and what are the sizes and locations of the speakers. thanks for the info in advanced
tbcaddy18
09-19-09, 09:54 PM
Just curious if anyone knows if its possible to replace my front 4x6 speakers with 5.25 speakers in my 1986 Cadillac Fleetwood Brougham (RWD)?
...I replaced front and backs a couple years ago with Polk Audio MOMO's, but im still not happy with the clarity and depth of the front 4x6's.
Also, what will the difference be if I add in an amplifier to my speakers right now?...is it just to make them more louder or more crisp?
Thanks,
Tabz
cadillacdriver25
11-24-09, 06:11 AM
Hello
just wanted to know if the new bose speakers in the sts 05-10 use also 1 ohm? so I could replace my blown STS (98-04) bose speaker with the newer bose speaker? so the can not blown again :)
if I use the original spk so it can happen again:(
thx
91STShopeful
12-05-09, 02:37 PM
How can I tell if i have the Delco Bose Gold System. The head unit in the car is Delco Bose, but looks like it is an aftermarket one (see pic), but the rear speakers are blown. From what I am reading, you just cannot go out and buy any brand of speakers of the same size and install them. Why is that? One other question, it is not a speaker question, but does pretain to the radio system, how do you test a power antenna to see if it works before installing in your car? I found an antenna at a junk yark that was in the down position, so I figure it must still work, since most antennas that dont work are usually stuck up. Oh this is for a 92 Fleetwood FWD.
Ludacrisvp
12-12-09, 05:20 PM
2 ohm
sure
So this would mean that Bose runs a 2 ohm sub and 1 ohm speakers?
or is that 2 ohm related to the Kicker Free-Air use sub you suggested?
I removed my aftermarket sub / amp a while back because the amp went bad causing the sub to go out too (when the amp powered on it caused the sub to bottom out several times then it was done before I could do anything about it).
This thread got me thinking of replacing the factory 10" with another free-air 10" instead of using an aftermarket box type setup.
I was looking at Crutchfield.com and they have some interesting replacements available.
If the Bose sub is a 1 ohm then I'm looking at this one:
Infinity 102.7w Kappa 10" (http://outlet.crutchfield.com/p_108K1027W/Infinity-102-7w.html?cc=02&tp=13722) 1 or 4 ohm selectable $162
Its DVC 2 ohm internally wired to give only choices of 1 or 4 ohm
RMS 50 - 350 watts
Peak 1400 watts
If it is a 2 ohm then I'm thinking about this one:
Infinity 100.9w Kappa 10" 2 or 4 ohm selectable $190.
Same specs as 1 ohm version.
However they have a really good price on a Kicker Comp 07C104 $45.00
Its a 4 ohm SVC
RMS 50 - 150 Watts
Peak 300 Watts
But if the Bose stock is
75 watts @ 1 ohm
37.5 watts @ 2 ohm? - most likely not worth it
18.75 watts @ 4 ohm? - def not worth it
or if stock is
75w @ 2 ohm
37.5 @ 4 ohm? - not bad for only $45
Any advice on what would be a good idea?
DonRSD
12-27-09, 07:59 PM
Fit Guide
2000-2005
Center Channel 3.5
A Pillars 2 inch
Front Doors 6.5
Rear Doors 6.5
Sub 10
well crutchfield had the spekers listed @ 5.25" all around the doors
onlinecarstereo.com has the fronts listed @ 6.5" and the rear doors @ 5.25"
i have 2 sets of pioneer 5.25" speakers for each door and the front door is a 6.5" :annoyed:
i didnt take off the back door yet as i was rather frustrated at crutchfield.com for providing me the wrong info on my front speakers....
can anyone confirm if the rears are 5.25" or 6.5"??
Nickatina
01-20-10, 01:56 PM
Topic really needs an update...
Nickatina
01-20-10, 01:57 PM
Anyone know the speaker sizes for an '84 Coupe DeVille? Doors & rear deck?
Nickatina
01-20-10, 01:59 PM
I'd also like to know that.
Nickatina
01-20-10, 04:18 PM
Don't know how accurate it is, but I found this on another site:
Cadillac Brougham 87-92 4x6 6x9
Cadillac Brougham 85-86 4x6 6x9
Cadillac Brougham Sedan 87-89 4x6 6x9
Cadillac Catera 97-99
Cadillac Cimmaron 82-88 3.5 6x9
Cadillac Deville Coupe/Sdn 90-93 3 1/2, 4x6 6x9
Cadillac Deville Cpe FWD 85-89 4x6 6x9
Cadillac Deville Cpe RWD 78-85 4x6 4x10
Cadillac Deville Sdn FWD 88-89 4x6 6x9
Cadillac Deville Sdn FWD 85-87 4x6 6x9
Cadillac Deville Sdn RWD 78-85 4x6 6x9
Cadillac DeVille Sedan 94-99 5.25 6x9
Cadillac Deville/FleetwoCustom Fit 73-76 3.5 6x9
Cadillac Eldorado 78-83 4x6 4x10
Cadillac Eldorado Coupe 92-94 5.25 6x9
Cadillac Eldorado Coupe 90-91 5.25 6x9
Cadillac Eldorado Coupe 88-89 5.25 6x9
Cadillac Eldorado Coupe 86-87 5.25 6x9
Cadillac Eldorado Coupe 84-85 4x6 4x10
Cadillac FleetwoCustom Fit Coupe 90-93 3 1/2, 4x6 6x9
Cadillac FleetwoCustom Fit Coupe 85-86 4x6 6x9
Cadillac FleetwoCustom Fit Coupe 78-84 4x6 4x10
Cadillac FleetwoCustom Fit Sedan 90-93 3 1/2, 4x6 6x9
Cadillac FleetwoCustom Fit Sedan 88-89 4x6 6x9
Cadillac FleetwoCustom Fit Sedan 85-87 4x6 6x9
Cadillac FleetwoCustom Fit Sedan 78-84 4x6 6x9
Cadillac Seville 92-97 5.25 6x9
Cadillac Seville 90-91 5.25 6x9
Cadillac Seville 88-89 5.25 6x9
Cadillac Seville 86-87 5.25 6x9
Cadillac Seville 84-85 4x6 6x9
Cadillac Seville 80-83 3.5 6x9
Cadillac Seville 77-79 3.5 4x10
DonRSD
01-27-10, 09:01 PM
Fit Guide
Deville
2000-2005
Center Channel 3.5
A Pillars 2 inch
Front Doors 6.5
Rear Doors 6.5
Sub 10
i just installed new speakers this weekend in my 2002 deville dts
front doors are 6.5"
rear doors are 5.25"
louieftw
01-29-10, 10:01 AM
I drive a 95 Seville SLS with the Bose Gold Series system. Should I go with 5.25" speakers up front?
hobbs1
03-25-10, 01:29 PM
i have a 93 fleetwood brougham and noticed the rear speakers are quite larger than 6x9 yet everywhere i check tells me that 6x9 is the size to use. but since the speakers that are there there appear to be in an adapter i am just curious if anyone knows of larger speakers going into the rear deck without too much modification or where i can find some factory sized speakers?
Candidsoul
05-15-10, 12:29 PM
I am seeing many conflicting sizes for the deville. Can someone tell me what size(s) are in my 2004 Deville (base) with non-bose? I took the doors off to replace the darn window regulators and they seem to be the same size but different ohms.
keelerdr
05-21-10, 11:47 AM
hobbs1,
I don't think there are any full range car speakers that are larger than 6x9, which is why all the places online are listing them as 6x9. If the stock speaker is considerably larger than a 6x9, you may be able to replace it with an 8 inch midbass driver. The 8 incher would be round though and only play mid to low bass. This may not be a problem though since the stock speaker may just of been seeing the low notes anyway.
I haven't checked the wiring diagram for your car but I know that for my 97 deville, the "6x9's" were called subwoofers and only received the low frequencies. There is a crossover built into the stock amp that takes the mids/highs and send them to the doors/dash speakers. This is why when people replace their 6x9's with two or three way speakers, they still only play the low notes :banghead:.
I don't have any experience w/the 8 inch midbass drivers. They are not very common...it is basically an 8 inch "free-air" (meaning no enclosure needed) subwoofer that does not play very low.
If you just want a little more low end, a basic aftermarket 6x9 speaker would work fine. I replaced my stock ones w/a pair of kicker 6x9s on sale for like $95 total. It was a noticable upgrade...until I went w/a JL 10w3 :cool2:
Hope this helps
larryP03
08-31-10, 02:30 PM
Does the 1 ohm speaker issue apply to non-Bose systems? I am looking to replace the speakers on my non-Bose stock system in my 2007 DTS.
Also, I noticed the fit chart only goes up to 2005. Any ideas on sizes for the 07 DTS?
Thanks.
giant h2
09-01-10, 08:32 PM
looking for speaker sizes for 93 allante?
Lorideslo
12-31-10, 06:00 AM
What is the size of the front and rear door speakers in a 2007 STS with Bose and a non Bose system?
IngeniusV3
05-08-11, 11:02 PM
Curious as to the speaker size for front and back in a 1990 Cadillac Seville. I checked online and a place said 5 and 1/4 inch for the front and 6x9 in the back. I would just like conformation. Also, would it just be simply buying them and installing or would I have to do anything special?
Danomadicone
06-18-11, 07:33 AM
Does anyone of the ohms and configuration of the speaker wirings for the 2000-2005 Devilles?
NerosTail
08-04-11, 10:00 PM
Okay guys, I thought I was confused before... There is all kinds of conflicting information all over the net. I am trying to replace my speakers. I have a 2001 Deville DTS with a Bose system. Every website I go to lists different speaker sizes.
Can someone tell me what are the speaker sizes, and where is the amp(s) located? I want to pull it all out and replace it with after market. But I want to actually buy the stuff first before I go tearing into my door panels and so on.
Ludacrisvp
08-05-11, 05:00 PM
Unfortunately those people out there that know the information seem to be unwilling to ever respond to a post in this topic. If I knew the answers I would tell you but I don't.
vincentm
08-05-11, 05:15 PM
Best thing to do is get an Alldata subscription. That will give you the exact speaker specifications for your car.
rxr
08-31-11, 06:25 AM
Guys i have a Seville SLS 03
Factory Front Speakers : 6" - (2 ohms )
Factory Rear Speakers : 5.25" (2 ohms )
Replaced with Sound Ordinance 6x7.5 - fits just fine. ( 4ohms )
The factory amp - is hardly firing these, the front channel speakers are more heard than the others..
What after market amp, would you suggest, or any other ideas..
Cheers
jeff.v
01-11-12, 03:36 PM
I have found that its a 2ohm and what looks like a shallow mount/free air type but does anybody know how big this thing really is? I'm looking to replace it with an aftermarket sub (Particularly a JL Audio) if I can get one to match size wise.
Anybody take look at this? I'm looking through here and it doesn't seem to be anybody has (other vehicles but not 06 CTS)
tyma1026
05-02-12, 03:57 PM
I have an 01 Cadillac Seville STS. In my dash there are three 2 inch tweeters. The front doors each have an 8 in sub. The rear doors have 6 in speakers. The rear deck has a 12 in sub.
Dash speakers measure 3.5 ohms
Front door subs measure .5 ohms
Rear doors measure 3.5 ohms
Rear deck sub measured 0 ohms
Unless my meter was acting up which I doubt these are the correct ohm ratings for these speakers/subs.
The dash speakers are in sort of a vented housing which makes it appear bigger and weirdly shaped.
The front door speakers are in sort of a bracket that doesn't really make the speaker appear any bigger.
The rear door speakers were not in any bracket but the plastic panel behind the speaker was in the way of my new speakers and o had to break it to fit them in. Im gonna cut the rest out and use dynomat to reseal it back off.
The rear deck is more obvious without taking anything apart. No bracket or anything that I remember.
I hope this helps some of you. I wish I would of had better directions before I started.
Vladillac Khrougham
05-29-13, 08:21 AM
Hello. I bought a 92 Brougham with a standard factory cassette head unit, a dead CDM (amp/tuner), and Polk speakers. I eventually replaced the bad CDM with a working unit, swapped out the cassette/only Head Unit with a Cassette/CD one which I believe is from a later model De Ville/DTS (this head unit is identical to the one offered in the Brougham with the exepinoin being that the five preset EQ buttons labled "A B C D E" are absent, with 2- slider controls, one for bas and the other for Treble. I also replaced the the disitigreated Polk 4x6 fronts with a pair of salvaged Delco ones, as the polks in the rear semed undamaged I left them in. Everything wouked well for a couple of months but now ione of the rear polk 4X9's is dying.
My problem is that I have seveal 6x9 Delco speakers but some are 10-ohm and the others are 4-ohm.
Any advice on which ohm ratting was original in the 92 Brougham? My GM shop manual only gives ohm values for the front speakers, which were offered in 2- different configurations on the 91/92 Brougham and referes to the rear speakers, (set up the same way in both the the base 4 speaker and optional 6 speaker) by 6X9s size.
Do you know it if it was was 10 or 4 ohms rear speakers, that were originally installed at the factory?
mikeymorehead
09-18-13, 11:56 PM
on an '01 Deville center channel is that one 3.5"?
mavric240
08-15-14, 12:25 PM
Question regarding speaker replacement for my 1998 Deville with the stock radio and currently stock speakers. (This is the non Bose system)
I understand that I have the following speaker set up:
Center Channel 4x6
Front Doors 5.25
Rear Door 5.25
Rear Self 6x9
The front dash center speaker and the rear deck lid speaker are one speaker and the rest are in pairs (if I understand that correctly). My question is what would be some good upgrade options to replace the factory ones? I am not messing around with the factory head unit but I would like to upgrade the speakers. I tend to lean toward Polk Audio and Infinity but looking for some input. Are there any Ohms issues to worry about or any other items that may be an issue?
Discobee
10-01-14, 12:17 PM
Fifth generation Seville w/Bose owners, if you're looking to get rid of the 8" Bose midbass in the front doors, this speaker adapter will adapt into a 6.5" speaker for $12
http://www.car-speaker-adapters.com/items.php?id=SAK049
chasd
01-06-15, 03:07 PM
I am trying to replace my Bose speakers (front door and rear door) on my 2004 DeVille DHS. Can't get any accurate info. I have read and searched repeatedly throughout this forum. Maybe I'm missing something? Questions:
1) Is the Bose speaker 2 ohm or 1 ohm?
2) Is the the front speaker 5 1/4 or 6 1/2? What is the rear door speakers?
badazzyellaboi
09-16-15, 12:57 PM
2003 Deville base, no Bose, no nothing :
Just wondering if anyone has had any luck with shallow mount speakers in place of the factory sub? Finally blew the sub and I need to get a replacement ASAP! I know there's a bracket back there, but does anyone know how deep it is? I read its about 6inches, but needing to verify. I will assume there's a difference in sound, but for what I'm trying to do, I'm not really worried about super bass (I recently got rid of my type-r & pioneer amp). I'm just looking to upgrade just enough to enjoy above average bass on the factory system. Open to suggestions...
