: B&B 3" Front Pipes
Bueller
07-27-08, 01:15 PM
I bought a used B&B but it came with front pipes that were fabbed for Kooks headers. :banghead:
I may do headers down the road, but I'm doing some Fstock Ax right now.
Does anyone have the std 3" pipes that connect the x-pipe to the stock cats that they want to sell? Also does the exhaust require a gasket at the cat connection? If so what does it look like? Thanks.
heavymetals
07-27-08, 02:02 PM
You can buy the connector pipes from B&B.
You will need gaskets and an adapter as the cat connection is 2.5" and the B&B is 3" diameter.
Furthermore, the stock connection fits into each other whereas the B&B is a flush mount.
My $.02?
Get the headers and cats and match the stuff up.
Bueller
07-27-08, 09:21 PM
Where do I get the adapter? I will call B&B tomorrow and see if they have it. I was just thinking I could possibly get the connector pipes for less from someone here.
heavymetals
07-28-08, 03:41 AM
Any good exhaust shop should be able to fab you up an adapter.
The caveat?
Probably won't be stainless.
Just a gasket, a flange with a pipe welded and bent and a clamp X2.
You have to have a mating flange that is 2.5".
Then you need to have the diameter of the pipe stretched out to 3".
CTSV_510
07-28-08, 11:05 AM
Sounds like a lot of work. Get the kooks headers and move on ...:sneaky:
Bueller
07-28-08, 12:40 PM
So does everyone on here with the B&B have this custom adapter with stock cats and manifolds? I thought most catbacks are simple bolt ons. Any Pics?
PISNUOFF
07-28-08, 03:41 PM
Sounds like too much work. You should just give up now and send me the X-Pipe.:bouncy::bouncy:
OldRoadDawg
07-28-08, 05:19 PM
Mine was a "simple" bolt-on, although the shop I had install it managed to screw it up by unthreading the cat flange studs, then re-installing them like a bolt, :banghead: cross-threading them in the process. Prime example of Murphy's Law.
I got new donut gaskets and flange studs from Luke @ Lindsay, drilled out the now sheared off studs, and ran a tap through the flange holes. Put the new studs in and slowly tightened the retaining nuts evenly and ... no leaks for 2 yrs.
Anyway..... the flange plate on the 3" B&B pipe draws up fine to the flange plate on the OEM cats.
My B&B is over 3 yrs old with a 'mini' resonator built into each header pipe before the actual resonator. I assume they are still building them now to the same dimensions, but I don't think they use the small resonator anymore in the head pipe.
