: Factory Installed Analog Phone Outdated?
07-18-08, 07:35 PM
I recently purchased a 2000 DTS. It has a factory installed phone in the center console. I called a cadillac dealer this morning to find out the procedure to activate the phone. He said that becuse the phone is analog and not digital that it cannot be activated. He also told me that my onstar feature on this car cannot be activated. I am looking for a second opinion.
07-18-08, 07:49 PM
Unfortunately, he is correct. The early onstar units used analog cellular communications which was discontinued completely by the FCC earlier this year.
Check out my thread on bluetooth conversion in this forum, perhaps that might interest you.
07-21-08, 08:43 PM
2002 is the turnover for the analog-digital conversion. Nothing earlier is supported.
07-27-08, 12:04 AM
You could modify it to work correctly though, As long as your OnStar uses the Class 2 data bus and not the older E&C data bus.
07-28-08, 04:47 AM
How? Any Diagrams/Schema ?
Thanks in advance
07-28-08, 07:10 PM
Mike.........Forget it........:horse:
07-29-08, 02:27 AM
This is the best i could decipher. A friend of mine did the conversion on his truck and it worked flawlessly..
Wire--------------------New Location-----------Old Location----Circuit No
Keypad Red-----------VCIMC1,2---------------VIU C2,F9------2517
Keypad Green--------VCIM C1,3---------------VIU C2, E5------2516
Keypad Supply-------VCIM C1, 6---------------VIU C2, E6------2515
Ground----------------VCIM C1, 7--------------VIU C2, F1------1051
Ground----------------VCIM C8, 8--------------VIU C2, E1------1051
Keypad Signal--------VCIM C1, 11-------------VIU C2, E4------2514
Battery Voltage------VCIM C1, 15-------------VIU C2, F16------2240
Battery Voltage-----VCIM C1, 16--------------VIU C2, E16------2240
Rem Rad L-----------VCIM C2,1---------------VIU C1,A8------367
Cell Voice low ref ---VCIM C2,2---------------VIU C1, A6------659 (old #372)
Class 2 data-----------VCIM C2,5--------------VIU C1, A2------1807
Drain (voice)----------VCIM C2,8-------------VIU C1, A9------814
Cel Mic Sig------------VCIM C2,9--------------VIU C1, B9------655
Drain (mic)-----------VCIM C2,10-------------VIU C1,B10------814
Cel Mic Sig-----------VCIM C3,2
Drain -----------------VCIM C3,5
