View Full Version : Kooks header gasket question
IownaCTS-V
07-15-08, 10:48 AM
I blew a left gasket... Was wondering if anyone knows where I can purchase a replacement gasket? Is the stock stainless not an option?
thanks!
The Tony Show
07-15-08, 11:14 AM
Use a stock one, and get some Copper Gasket Compound from Autozone. Smear compound on gasket, install and forget.
ctsv154
07-15-08, 12:10 PM
I used stock gaskets and never put anything on mine. Not a single leak.
trukk
07-15-08, 12:27 PM
I've used the kooks and the stock gaskets, and they both leak a bit. If you drive it long enough and hard enough any gasket will leak.
-Chris
CTSV_510
07-15-08, 12:38 PM
Stock GM gaskets here. Call Luke ------------------> Lindsay Cadillac---------------->
SkullV
07-15-08, 12:48 PM
Percys Seal-4-Good dead soft aluminum gaskets, have never leaked for me!
CTSV_Rob
07-15-08, 12:57 PM
^^ That's what I'm running on the B&B's and no leaks for me.
heavymetals
07-15-08, 01:08 PM
If I recall, some of the KOOKS suffered from non-flatness.
You can search for that.
Scatillac
07-15-08, 01:10 PM
Any time I put headers on a Gen III/IV, I use new GM factory bolts (and GM gaskets).
Vibration is the enemy here! The GM bolts have a threadlocking compound that is not affected by heat and will not loosen up like uncoated aftermarket bolts. It is a single use compound, so new bolts need to be used each time the headers are off.
Start them in (finger tight) and when you get them all in, tighten (torque) them from the center outward, alternating from front to rear, bolt by bolt.
The GM bolts are not pretty and shiny like some of the aftermarket stuff but they sure do work.
I have no leaks in either my truck (over 3 years) or my V (over a year). I've also done two Camaros and one other truck for (younger...read: daily thrashing) friends and have not heard anything about leaks. I see these guys every few days and they would be slobbering around and whining if they had any issues.
CTSV_Rob
07-15-08, 01:14 PM
Good idea to re-torque after a few heat cycles as well. (recommended).
CTSV_510
07-15-08, 01:40 PM
Remember the ft-lbs?
heavymetals
07-15-08, 01:46 PM
18 ft lbs.
CTSV_Rob
07-15-08, 02:03 PM
:yup:
