: Rattle when shifting with my UUC
07-14-08, 07:55 PM
I have had my UUC shifter installed for about 12,000 miles. It was totally quite but now is starting to rattle on each shift and as I hold the revs up in any gear. It sounds like a click or snick almost metalic when I shift.
It seems to get better when I push on the passenger side of the console. I looked for loose bolts but didn't find any, although I didn't go underneath to check the one on the bottom. I don't get it. It is driving me nuts. :bighead:
07-15-08, 07:06 AM
where in fl? did you do the install?
07-15-08, 07:24 AM
Baked beans.
(j/k Other than a bump, I'm not much help, am I?!)
07-15-08, 08:56 AM
Sounds like the allen head bolt that holds the shifter to the linkage has worked itself loose. Tighten the nut back up and it should be fine. I would recommend a nylon tip nut so it doesn't work itself back out.
07-15-08, 11:38 AM
Anyone know the size of that bolt and nut so I don't have to take it off, measure, install, run to the store, uninstall and replace? Good call on the nylock. I will post findings once I get there. Thanks,
07-15-08, 02:14 PM
Dang it I don't remember the size.....it's pretty small though. Maybe Luke could help on this one??
