: 96 Caddy speaker instalation help
07-14-08, 04:16 PM
I have a 96 Deville and want to replace the front door speaker. How do I get the front door panel off?
07-18-08, 11:29 AM
Ok what you're going to do first... remove the little plastic trim panel from behind the door handle with a small screwdriver or something equivalent. Next, gently pry up on the window/lock panel to lift it from the door panel and unplug the connectors. The door panel rests on a set of hooks so if you pull it straight up and kinda rock it back and forth it should come off. Mind the door handle.
Have a helper nearby to hold the door panel while you remove the small connector from the little illumination light bulb situated above the door handle. Unplug any remaining connectors including the tweet cables before completely removing the door skin.
There should be four bolts holding in the Door speaker... hope that helps!
