View Full Version : car won't start
dutch1944
07-12-08, 01:26 AM
i just purchased my allante two days ago and it ran great, started right up and i have logged probably 2-300 miles in these past two days with no problem.
then tonight i backed out of my ladyfriends driveway, headed down the street, made a right turn, went about another block and the car just died!. it has electrical and will turn the engine over, but doesn't seem to fire at all.
i was thinking i read someplace about the theft system shutting yhe car down after 10 seconds if something wasn't right. did i imagine that or could it be something else. car has 130,000 miles, but runs great (except for now), doesn't leak, smoke, etc. i just love it, but now i don't know what to do. i'm a "hands on" guy that likes to make my own repairs, but haven't had the allante long enough to figure some things out.
any suggestions? it's a 1990
thanks inadvance, bud
c5 rv
07-12-08, 08:22 AM
Welcome and congrats on your new car. It sounds like it could be a fuel problem. I would check the following:
- Add gas. If this car is brand new to you, it may have a stuck fuel gauge and you simply ran out of gas.
- Replace fuel filter. Again, you may not know when that was changed. I had a 99 GMC pickup that coasted to a stop on the freeway and wouldn't restart. It turned out that the dealer never replaced the fuel filter as specified in the last major service visit.
- Check the fuel pump.
carnut
07-12-08, 01:23 PM
There is a schraeder valve on the fuel rail between the injector rails. Remove its cap and depress the valve. Gas should shoot out of it. If so, pull a wire off one of the front spark plugs and verify spark, then report back. The theft system will not allow the car to start or even crank over if activated, so thats not the issue. Nothing more than any other car, verify spark and fuel and report back.
dutch1944
07-12-08, 01:31 PM
thanks guys,
i'm headed over to my ladyfriends in the next hour or so. will do some checking and get back to you.
i really like this car, and bought it as an alternative to motorcycling. i'm 64 and have decided to give up motorcycles. just a little disappointed to have something like this happen after two days of ownership.
thanks for the advice, glad to know it's not anything to do with the theft device.
bud
carnut
07-12-08, 02:45 PM
Before depressing the valve, turn the key to RUN for a few seconds. That will pressurize the fuel system to verify the fuel test. With the gas cap off and someone turning the key to run, you should hear the in tank pump buzz for a few seconds with your ear close to the filler neck. I think you've discovered why it was sold! And I presume theres more than 2 or 3 gallons in the tank?
dutch1944
07-12-08, 03:17 PM
"And I presume theres more than 2 or 3 gallons in the tank?"
unfortunately yes! i just filled it up and had driven about 60 miles. i say unfortunately if i have to drop the tank.
maybe you meant, am i sure i have fuel.
my ladyfriends and her son just went shopping, so i'll wait 'til he gets back to help me check the things you mentioned.
thanks, bud
Edahall
07-12-08, 03:29 PM
Also check the distributor to make sure none of the electrical plugs have not fallen out. The electrical plugs get old and brittle and loose their little clips that hold them into the receptacle.
dutch1944
07-12-08, 03:34 PM
i just turned the switch to the run position and pushed the schraeder vavle. about a teaspoon on fuel dribbled out. i pushed it a second time and none came out.
friend of mine said take the air filter off and spray starting fluid into the system and if it's a fuel problem, this should at least let it run a little....recommended or not.
edahall, wires look good, but haven't confirmed yet that it's getting spark...here by myself right now.
thanks, bud
carnut
07-12-08, 04:33 PM
You have no fuel pressure. So check fuses related to fuel pump. Ck also the wiring connector at the oil pressure switch. If loose there, it will disable the pump. Switch is just to the left of the upper radiator hose where it connects to the thermostat, just above the oil filter, its vertical. Also check the oil pressure sensor that is horizontal below the oil sender for a loose connection. Lift up the center ash tray assembly to get to the fuses. Test each one, key on, with a test light for power on both sides. The fuel pump relay, I think, is in the bank of relays hidden behind the coolant recovery tank. 3 of them should be the same part number. Swap them if all fuses are good. Owners manual should identify the fuses. Rather a bugger to remove the flex hose at the throttle body inlet to spray and potential backfire and fire.
dutch1944
07-12-08, 05:42 PM
thanks a million for all the good info carnut. one other thing i did that might have contributed to this, is i washed the engine at a car wash after i changed the oil/filter and had the tranny gasket replaced. i tried to keep the spray away from vital components(electrical)and did drive the car probably a hundred miles after that with no problem.
thanks again, really appreciated. have to go to a birthday party this evening, so will be tomorrow before i get back to it.
bud
carnut
07-12-08, 06:24 PM
The fuel pump fuse is no. 19 in the panel under the ash tray. Looking from the left upper corner count down to the 3rd ? column to 19. Washing the engine might be a good clue because both oil sensors are next to the oil filter adaptor! Gently unhook the plastic locking collar around the oil sender wiring, remove plug and apply dielectric grease to the connector. Same with the oil sensor mounted below it. Good rule of thumb is every time a wiring plug is removed, apply dielectric grease to the pins in the connector. Most all connectors having to do with reading the sensors underhood are powered at much less than 12 volts and low amperage so loose, corroded connections are common.
Stealth
07-13-08, 12:59 PM
I keep a pressurized can, 6 oz I think, of the di-electic grease and every connector that I touch gets it, exceptions are inside the fuel tank and transmission. I believe that is one of the secrets of my aging cars running trouble free.
FYI - the fuel rail should sport around 40 psi of fuel pressure. If you got the key ON and you push the schraeder valve, there should be lots of fuel. In comparison, I believe your garden hose runs about 15 psi .. how much water would you get from a pin hole in a hose? IF it trickles, as carnut stated, you got fuel delivery issues: fuse, wiring, pump, filter.
the fuel pump you can hear running for a couple of seconds when you first turn the power on, before you crank the engine. IF it is silent, it aint running.
dutch1944
07-13-08, 02:57 PM
thanks again for the info guys.
i've had the car towed to my house where i have access to tools, jack, etc.
i've checked all the connectors/fuses, they seem fine. now i have jacked the car up and removed the fuel filter. with it removed, i turned the switch on and the pump puts out about a 3/8" diameter of fuel, but it didn't "shoot" it out, just sort of came out the line like a water faucet in the house when it's barely opened. i know with old mechanical pumps the fuel would shoot six feet or so when they were disconnected on the carb side if it was working right...is an electrical pump suppose to do the same...i.e. shoot the fuel out from the tank line 5-6 feet?
when i keep the starter turning, it will give me a continuos flow, but again, it's just running out of the line, not shooting.
thanks, bud
Stealth
07-13-08, 03:17 PM
thanks, bud
that may be fine .. now we know the pump IS running, wires are ok, fuses are ok .. but .. it is one thing to get flow, it is a whole different thing to build and maintain pressure. a pump can easily pump under no pressure and fail under pressure.
we need to know how the flow is at the rail .. SO .. get to the parts house and get a PRESSURE GAGE to test fuel pressure at the rail. I think they can be had for under $40, they arent that expensive.
REALLY do this before you go tearing into the fuel tank.
dutch1944
07-13-08, 03:36 PM
thanks stealth,
i'll probably wait 'til tomorrow now. have a friend who will loan me a fuel pressure gauge.
i really hope it is a pump. i know that's a big job, and i'll probably take it to my mechanic friend simply because he has a lift that allows him to get the job done quickly. maybe electrical would be cheaper to repair, but just tracking it down seems a huge undertaking to me.
i'll let you know what i find.
thanks again for all the advice,
bud
Stealth
07-13-08, 04:58 PM
If it comes to changing the pump, maybe carnut can shed some light on the level of difficulty .. he dealt with these cars at the dealership. :thumbsup:
i have changed fuel pumps but not on any Allante, yet .. KNOCK ON WOOD !
dutch1944
07-13-08, 05:46 PM
thanks stealth,
carnut has given me a lot of good advice, but i'll probably take the car to my mechanic friend. i'm 64 and have been around old cars all my life...used to have some 50's custom cars, but now with a bad back and no lift other than a floor jack, i'd rather let somebody else tackle the tank. my brother has a garage, but it's 200 miles away, and i'm sort of anxious to get it back on the road. the three days it ran, i really enjoyed it.
bud
c5 rv
07-13-08, 07:55 PM
... i'm sort of anxious to get it back on the road. the three days it ran, i really enjoyed it.
bud
These cars are rather addictive, aren't they?
dutch1944
07-14-08, 10:46 AM
borrowed my friends fuel pressure gauge this morning and it has exactly 40 lbs pressure, so guess the pump is o.k.
i really haven't checked the fire yet, as i was going more for the fuel being the problem. if there's 40 lbs pressure at the valve, does that pretty much eliminate the fuel as the problem? as i stated before, the fueses are o.k. and connectors are clean.
i'll check for fire next.
thanks, bud
dutch1944
07-14-08, 11:15 AM
well, guess i should have checked for fire first. the way the car died on me, just thought it was fuel.
but, i have no fire to plugs. going to talk with my mechanic friend.....where should i start now?
thanks, bud
c5 rv
07-14-08, 11:22 AM
Maybe a grounding problem? I had a new 81 Pontiac Phoenix company car that lost the ground strap to the engine with 20 miles on the odo. It coasted to a stop and would not restart.
Stealth
07-14-08, 11:38 AM
thanks, budthanks a million for all the good info carnut. one other thing i did that might have contributed to this, is i washed the engine at a car wash after i changed the oil/filter and had the tranny gasket replaced. i tried to keep the spray away from vital components(electrical)and did drive the car probably a hundred miles after that with no problem.
bud
at 40 psi, pump sounds fine to me. arent you glad you did the pressure test and not dropped the tank?
No fire to ANY of the plugs?
- doing a ground check is easy, Ohmmeter between engine block and car frame .. or .. you can put a jumper cable, block to frame and give it a crank. I would use the stud on top of the strut tower, the one your OWNER MANUAL tells you to use for battery jumping.
- coil .. most likely & really easy test .. do you have FIRE on the coil wire to the distributor?
- distributor assy and internals - next on the list .. if it has incoming fire, but nothing going out, you found it.
dont mess with the spark plugs or wires, unless the no fire is to one or two. if no fire to any, that is not the problem.
BTW, fuel pumps rarely just die without notice. they slowly fail and you see a tendency for longer and longer cranks to start the engine, or you hear the pump getting louder with time.
That engine wash continues to bother me .. one has to wonder where water got in ..
As a side note, I highly discourage pressure washing an Allante engine. Too many sensitive electric gismos.
Best bet is to spray it with Simple Green and rinse it down; not pressure wash it. Leave the pressure wash for the underside of built up gunk, but not the top side.
keep us posted ..
dutch1944
07-14-08, 12:41 PM
[B]ON THE ROAD AGAIN!!!
thanks for all the help guys. if i'd pulled the distributor cap first while at my girlfriends house, could have saved myself a $100 tow bill.
pulled the cap and the rotor had broken. i think one of the screws that holds it on had not been tighten. when i went to install the new one, the one screw would only go in about half way, and that's where the rotor was broken. i tapped it out good so the new screw would tighten good and it fired right up. idled rough for awhile, but think it had flooded a little with all the off/on i'd been doing.
really stupid of me for not checking the fire first, but because i was at my girlfriends house when this happened, was limited to the tools at hand.
thanks again to all who gave advice, now i can go enjoy this baby a little. great day for a drop top here in kansas city.
bud
Stealth
07-14-08, 12:52 PM
thanks for all the help guys. [B]if i'd pulled the distributor cap first while at my girlfriends house, could have saved myself a $100 tow bill.
bud
hey .. understandable .. .. when I am with girl, messing with a damn Allante is the very last thing in my mind. :bouncy:
since the rotor was broke, there is a darn good chance the cap is cracked .. should replace it.
one more advice? no one should own an Allante unless you belong to the 100+ mile tow service AAA ... :thepan:
