: 2001 SLS Head Unit Removal? Looking for guidance:
07-04-08, 01:10 PM
Hi, I just purchased a 2001 SLS and I am looking to remove the cover plate and pull out the head unit. Can someone please provide me with the procedure? I want to be careful not to break anything. I tried the search but could not find anything. I had a 2003 EXT and the procedure was pretty simple.
I am looking to add in Sirius. I already have a kit but am considering going with a different head unit. Also, I am looking for suggestions on a Nav unit for this car.
07-04-08, 01:21 PM
kippjones, You may have some luck down in Technical: Audio, Video, Alarms.
07-04-08, 05:50 PM
Thanks, I will try there.
10-03-08, 05:43 PM
Anyone know how or have a guide?
10-03-08, 07:47 PM
replace it with a factory nav only unless you want a viable nightmare...
plus it will keep everything working
removal instructions can be found on metraonline.com
find the dash kit for your car and dl the pdf
03-28-09, 09:32 PM
This place has every instruction you could want. Some are $5 or so. This is the door removal instructions for example.
