View Full Version : Catera - Mustang Engine Swap, Possible?
aidsxcore
06-22-08, 02:52 AM
Dont tell me to buy a new car.
I want this done.
Can it be done?
I wanna know what id need to change, i can get the money. I know its gonna be pricy and you may say its not worth it.
i want something unique, my catera is gonna be a sleeper.
i was thinking about the LS1 but i havent found any support, id see all these threads but nobody here has actually done it.
Now the Mustang-Catera engine sizes arent a huge difference. From what i know.
Tell me what i need to know =P
dkozloski
06-22-08, 06:20 PM
How do you plan on getting it past the EPA so you can drive it. About a million bucks would be a good start.
CadillacSTS2003
06-22-08, 07:31 PM
rofl
your going to put a Ford engine into a GM car...
there have been LS swaps do a search and this is a Lightenfinger Catera which was built and parts exist for it, as well as the Holden V8
aidsxcore
06-22-08, 11:19 PM
The Mustangs V6 is about the same size.
Rear Wheel Drive
I dont see why it couldent be done.
Its not like a big upgrade to a V8
CadillacSTS2003
06-23-08, 05:21 PM
thats even worse
a V8 swap in some twisted way is at least worth while
V6 is pointless....
aidsxcore
06-27-08, 11:12 PM
The 3.8 on the stang has much more support and reliability.
the 3.0 in the catera is a peice of shit with a ****ing shitload of problems.
that and its a cadillac engine which is alot priceyer to fix.
and the fact that this car basically has no ****ing support from cadillac whatsoever.
AND the stang engine is highly modify-able with kits already pre-made.
CadillacSTS2003
06-28-08, 10:47 AM
hahahaha
1 thats not a Cadillac engine try Opel....
2 you bought hat "pos" so whats that go to say about your logic...
3 the Catera weighs ALOT more than a Mustang so idc how you look at it, less you dump some small block V8 in there your NEVER going to haul
i tried to take this seriously but right now your attempts to bastardize your car have reached an all time high, youll still be slow no matter what V6 you dump in there...
Chicano-Mexicano
07-02-08, 06:38 AM
By a stang then
the 3.0 in the catera is a peice of shit with a ****ing shitload of problems. that and its a cadillac engine which is alot priceyer to fix.
Isn't that you fault for buying it and STS2003 is right its an Opel engine.
Again isn't that you fault for not researching your car to begin with, I mean I wish their was a supercharger for my 4.9 but they don't make one so tough shit buddy.
Again by a stang then.
elvin315
07-27-08, 03:18 AM
I want this done.
Can it be done?
If you're still interested in a Catera engine swap take a look at the Catera forum. Lots of swaps in progress. One owner is installing a supercharged GM3800 V6. Generation II (L-67), 255 bHP @ 4600 rpm, 280 ft-lbs @ 2500 rpm.
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/129919-3800-supercharged-v6-catera.html
A few others are recreating the Opel Omega V8 using parts from Lingenfelter Performance. That car was in the final stages of preproduction before GM nixed it due to problems with the cooling system's ability to keep the engine from overheating at Autobahn speeds. (Ridiculous. GM has been cooling that small block V8 for 50 years. They couldn't find a solution?) These are not kits and don't come with instructions. There's a lot of fabricating and scrounging to do but the guys have bought the parts with the hope of making the Catera that Cadillac should have from the start.
http://cgi.ebay.ca/Cadillac-Catera-LS1-LS6-V8-engine-conversion-Opel-Omega_W0QQitemZ370065509020QQihZ024QQcategoryZ6763 QQtcZphotoQQcmdZViewItem
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/117000-halleluja-catera-v8-project-underway.html?highlight=lingenfelter
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/130818-cant-wait.html?highlight=lingenfelterhttp://cgi.ebay.ca/Cadillac-Catera-LS1-LS6-V8-engine-conversion-Opel-Omega_W0QQitemZ370065509020QQihZ024QQcategoryZ6763 QQtcZphotoQQcmdZViewItem
The Omega and Catera are virtually twins. All the parts for the Omega V8 will fit into the Catera. Lingenfelter bought Opel's inventory of Omega V8 parts with the intention of building them for sale in the US but the plan was shelved when John died. He had already squeezed a 7.0liter/427 cubic inch Corvette C5R engine into a Catera now named the Catera V by her owner. He used Holden Commodore drivetrain parts and beefed them up to handle the 500 HP and 500 ft/lb of torque. This is the ultimate sleeper Catera. Take a look.
http://www.pbase.com/elvin315/the_catera_v
Elvin
malachi
09-28-08, 01:11 PM
I am all for swapping motors into what ever you want.
Here is the first thing you need to look into.
quad4rods dot com
Why you ask? I pioneered a great deal in the Isuzu world. I found how to swap all sorts of motors into Isuzu cars (GEO Storms). One of the many things I have figured out was the compatability of various engines that bolt up to my transmission.
One of those being the 3.0 54*. (along with 2.3/2.4/ECOtec/Saab 2.0t/2.3t and a slew of other odd motors in the GM family.)
Anyway, the link above is to a place that makes adapters for the Quad 4 motor, and the ECOtec which depending on the specific engine, has your bolt pattern. They make adapters to bolt the engines to T5 and other transmissions.
What this means to you, is that you can use the adapter to bolt your stock trans to a Ford motor. How you would space the flywheel/flex plate is up to you.
Now while the V8 302/5.0 swap sounds fun, the reality is it will involve quite a bit of work to make all your electrical system to play nice. you will lose many things like the various suspension electronics, ABS, and who knows what else. Most asspects can be overcome through the use of your own relays and wiring for fuel pumps (which will be grossly over powerful for a carby), and other things like your needed new custom dash.
If you go with a full 5.0 HO swap with fuel injection, you are in for a nasty bit of nightmare wiring.
Good luck.
