: Something's not right with this V...
GOTTSPD
06-20-08, 09:50 PM
Saw this on Craigslist... I don't care for the black rims, but to each his own. Nevertheless, it certainly appears to be a V, but look at the dash... The gauges are V gauges, but why doesn't it have NAV? All V's have nav............
Maybe the dealer didn't feel like putting a new nav back in when they realized that they couldn't fix the silly buttons (where the paint peeled off).
http://washingtondc.craigslist.org/nva/car/726998693.html
http://images.autouplinkusa.com/images/uv_images/6602/Originals/1G6DN56S95011105206.JPG
Civardi
06-20-08, 10:03 PM
This looks just like the POS I almost drove to UT for. Vin is different though but the owner did not seem on the up and up. Didnt really want me to pick it up.
the cadillac kid
06-21-08, 02:51 AM
someone said that the V in Mr. & Mrs. Smith was also "Navi-less" ... that movie was in 05 also.
could be a select few V's made without nav...?
CTSV_Rob
06-21-08, 03:21 AM
Must be getting boring in the CTS forum.
rand49er
06-21-08, 09:48 AM
GMBound has an aftermarket Nav. His is integrated with a B/U camera ... really cool, too!
This one is different, but could be aftermarket, also.
MVP
06-21-08, 01:39 PM
Never heard of tires either, but everything else looks "V"
jbss71
06-21-08, 02:00 PM
could be a select few V's made without nav...?most of the time they have a few cars to do movies. so it might not have been the same car they showed driving
ROG
06-21-08, 02:58 PM
Here is VIN check on that car thanks to Lustreblade...
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 05/21/2005 25 miles 05/21/2009 50025 miles
72/UNLIMITED SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/21/2005 25 miles 05/21/2011 Unlimited miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/21/2005 25 miles 05/21/2013 80025 miles
48/50000 CALIFORNIA EMISSIONS 05/21/2005 25 miles 05/21/2009 50025 miles
84/70000 CALIFORNIA SELECT COMPONENT 05/21/2005 25 miles 05/21/2012 70025 miles
72/100000 LUXURY CERTIFIED PRE-OWNED LIMITED WARRANTY 05/21/2005 25 miles 05/21/2011 100025 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/03/2008 336019 # J1500 - ENGINE FRONT MOUNT REPLACEMENT - RIGHT SIDE 45286 miles
06/03/2008 336019 # Z7902 - 2-DAY COURTESY TRANSPORTATION 45286 miles
04/21/2008 332510 # D4450 - A/C SYSTEM - ANALYZE 43012 miles
03/11/2008 329356 # J0839 - CAMSHAFT TIMING GEAR/CHAIN SET REPLACEMENT 40442 miles
03/11/2008 329356 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 40442 miles
03/11/2008 329356 # J6360 - POWERTRAIN CONTROL MODULE REPLACEMENT 40442 miles
02/11/2008 327147 # J9995 - CUSTOMER CONCERN NOT DUPLICATED 39100 miles
02/11/2008 327147 # F9995 - CUSTOMER CONCERN NOT DUPLICATED 39100 miles
02/11/2008 327147 # Z7903 - 3-DAY COURTESY TRANSPORTATION 39100 miles
02/11/2008 327147 # C2368 - GRILLE, DEFROSTER OUTLET (ONE OR BOTH) - REPLACE 39100 miles
02/11/2008 327147 # N2540 - SWITCH - HAZARD WARNING - REPLACE 39100 miles
02/11/2008 328147 # F1280 - PROPELLER SHAFT ASSEMBLY - R&R OR REPLACE 39100 miles
02/11/2008 328147 # D2774 - HOSES, HEATER (WITH AIR CONDITIONING) - INLET - REPLACE 39100 miles
03/09/2006 040628 # H3060 - PARKING BRAKE ACTUATOR REPLACEMENT 18729 miles
03/09/2006 040628 # C8870 - INFLATABLE RESTRAINT PASSENGER SEAT SUPPRESSION MODULE REP 18729 miles
03/09/2006 040628 # E0724 - SENSOR, LOW TIRE PRESSURE WARNING - REAR - RIGHT - REPLACE 18729 miles
03/09/2006 040628 # Z7904 - 4-DAY COURTESY TRANSPORTATION 18729 miles
11/26/2005 037639 # E0719 - TIRE VALVE STEM GROMMET REPLACEMENT 12191 miles
10/14/2005 156932 # R0760 - RADIO, REMOVE AND REPLACE 9071 miles
10/14/2005 156932 # C2740 - DOOR AND/OR PAD, CONSOLE COMPARTMENT - R&R OR REPLACE 9071 miles
10/14/2005 156932 # C4021 - TRIM ASSEMBLY, QUARTER - LEFT - R&R OR REPLACE 9071 miles
09/30/2005 156628 # B7280 - HEADLAMP - AIM 9070 miles
09/30/2005 156628 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 9070 miles
09/30/2005 156628 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 9070 miles
06/15/2005 032496 # J5670 - MASS AIRFLOW SENSOR REPLACEMENT 2875 miles
06/15/2005 032496 # C4660 - TRIM, REAR COMPARTMENT END PANEL - R&R OR REPLACE 2875 miles
06/06/2005 032164 # B7289 - HEADLAMP/COMPOSITE ASSEMBLY - LEFT - REPLACE 2729 miles
06/06/2005 032164 # Z7903 - 3-DAY COURTESY TRANSPORTATION 2729 miles
03/08/2005 029088 # B1635 - HANDLE AND/OR LEVER, HOOD LATCH CABLE - REPLACE 1552 miles
03/08/2005 029088 # B7288 - HEADLAMP/COMPOSITE ASSEMBLY - RIGHT - REPLACE 1552 miles
03/08/2005 029088 # C6871 - COVER AND/OR PAD, FRONT SEAT CUSHION - LEFT - R&R OR REPLA 1552 miles
06/21/2004 A11052 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
the cadillac kid
06-22-08, 12:36 AM
JonCR96Z
06-22-08, 02:42 AM
Maybe they swapped with a regular CTS before trading it to Koon's.
