: My car has the shakes
pete15cool
06-20-08, 12:47 PM
When my car is in park or neutral it shakes. I turned off the a/c and still stakes. I notice the gas mileage dropped from 20 to 16 mpg. I might think it is the maf. I attached some pictures to the forum. I was think of the getting an ohm meter to measure the IAT sensor or air temp sensor. I know the power of the maf.
there are five wire
staring from the left
yellow
black with white stripe
red with black stripe - power wire
orange - maybe maf
orange - maybe maf
Can someone tell me which is Intake temp sensor and ground.
Thank You,
Pete
Last time I check, air flow sensor can cost up to $300
pete15cool
06-20-08, 12:49 PM
Sorry here is the picture.
Again,
Thank You,
Pete
ascariSTS
06-20-08, 05:35 PM
I'm not sure if throttle body has anything to do with this. My car's shakes started after they replaced the throttle body.
I wonder if anyone has a clue.
dkozloski
06-20-08, 06:29 PM
What codes are you getting?
pete15cool
06-21-08, 09:33 PM
No codes right now but recently I changed the air filter for stock to K&N air filter.
Pete
dkozloski
06-21-08, 10:54 PM
It is very common for a cold air intake to upset a Northstar and cause it to run lousy as well as providing very limited to no benefit. I'd put it back like it was. Also a little excess oil on a K & N filter element kills a MAF until you can get it clean again.
C&C
06-22-08, 07:25 AM
Dk is right, it may be oil on the MAF sensor. These can be cleaned but you need a specific MAF sensor cleaner, and you need to be careful as they are fairly delicate.
I had a similar problem with my Olds Bravada, and thought I had messed up my MAF (I had just switched to K&N) but after diagnosis, it was determined to be an O2 sensor; so in my case, it was just a coincidence that I had changed the air filter. This may also be the case with you.
pete15cool
06-23-08, 10:51 AM
Can ANYONE tell me which temp sensor wire is on the MAF? I have listed the color above.
