: Differential Diff Install
lollygagger8
06-20-08, 09:11 AM
Ok I want to start out saying I'm posting this because I hope it helps someone else thru the install/take out process that I just went through. I'm sure the day will come when you are out of warranty, and you need to replace your broken diff. I did this not knowing much of anything about it except for what ewill3rd helped me out on as I went thru it. So a HUGE thanks to ewill3rd for answering my PM's and questions along the way.
If you don't understand something, PM me and I'll be happy to explain.
You are going to need the following tools:
21MM Socket (almost all bolts/nuts on knuckle are this size)
21MM Gear Wrench (essential that it's a GEAR WRENCH...you'll see)
34mm Deep Socket (Spindle Nut on Hub)
18mm socket
10mm alllen wrench
8mm allen wrench
Long 1/2" Breaker Bar
Masking Tape/Marker (for marking all the bolts you are going to be removing)
Beer of Choice
Long Pry Bar
Parts for new/used diff:
Two Axle Seals
Vent
Spindle Nut
Seal Protector (optional but recommended)
1st thing's first. You have to remove the RIGHT REAR knuckle assy from the car in order to get the diff out, which is the majority of the entire job.
After you take the caps off the lug nuts, Loosen up the RIGHT REAR tire Lug Nuts. Jack up your V as high as your jack will allow in Jack Stands. I did this in my driveway on my back without a lift, so you'll need to get a good amount of room to work.
Once up in the air, remove exhaust including resonator (or xpipe). If you need directions on how to do this, you shouldn't be attempting this. Once exhaust is off, remove the bolts marked (#2) in the picture. They are Allen Head bolts and are 8mm. (#1) is where the half shaft/drive shaft hit the floor board when my first diff broke. It's slightly out of round, but hasn't produced any sort of vibes (yet...crossing fingers) Put a jack stand underneath the "drive shaft" to keep the weight of the front bolts holding it to trans.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff1.jpg
Next remove the RIGHT REAR wheel exposing the hub/caliper. You need to take the spindle nut off the axle first. This spindle nut is 34mm. Look at (#4) in the picture below. You need to place a drift punch or equivelant(I used the allen wrench) in between the slots in the rotor and the caliper. This will keep the rotor/axle from turning while you are cranking down on the spindle nut.
(#4) shows where the punch/allen wrench goes when you are TIGHTENING the spindle nut. When LOOSENING the spindle nut, the punch/allen wrench goes on the other side of the caliper in the slots in the rotor.
(#3) is the Top Caliper Bolt which is 18mm. The top bolt is longer than the Bottom Caliper Bolt so label them with the tape and marker (just to be safe)
http://i132.photobucket.com/albums/q16/n2havnfun2/diff2.jpg
Once the caliper is off, tie it up and out of the way. I used a bungee cord and wrapped it around the shock. Now is a good time to place a jack under the lower control arm since the bolts you will be taking out will make the knuckle assy/hub sag.
(#5) shows the caliper mount where the top bolt was. (#6) is nut holding in the Ball Joint. If you want to rent a Ball Joint Puller, be my guest. What I did (and ewill3rd does) was use a 1/2" extension for a socket wrench BACKWARDS (so the opening was facing the threads/nut. I loosened (not removed yet) the nut and then put the extension on the nut and hit the ext. with a hammer. One good crack and the Ball Joint popped loose.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff3-1.jpg
(#9) Is the bolt holding the Trailing Arm to the Knuckle. Remove this one first cuz the lower control arm will sag once the other bolts are out, and it's just more of a PITA to take out. Using the 21mm socket on bolt head, use the 21mm Gear Wrench on the nut. (#8) bolt is also 21mm and needs to come out. Label the Bolts/Nuts (tape and marker) and set aside the other bolts. (#7) is just the bottom of the Caliper Mount where the Bottom bolt came out.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff4.jpg
(#12) is the ABS Wheel Sensor. BE CAREFUL WITH THIS. Unclip it and keep it up and tucked away from everything. (#11) is the Emergency Brake Cable. You don't need to remove this, and actually ewill3rd said it was ok to let the enitre knuckle assy/hub hang by it once it was removed. <- Less work!
(#10) is the Lower Control Arm Bolt, which was 21mm. Remove it and label and set with other bolts. When you take this out the knuckle should only be held in by the shock mount bolt which is 21mm.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff5.jpg
(#18) is the Lower Shock Mount. Remove the 21mm Bolt/Nut and the Knuckle should be free (if I haven't missed anything)
(#19) is just another view of the Trailing Arm Bolt/Nut. Sorry the numbers are out of order, I forgot this pic. At this point, the axle half will be connected to the Hub/knuckle assy still. Holding the axle splines straight with your knee and pulling the knucle towards you, it should slip out no problem. Now that the knuckle is free, place it off to the side and let it hang by the Emergency Brake Cable.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff9.jpg
TAKE A BREAK A DRINK A BEER (OR TWO)
Ok now for the Diff itself.......
Once you get the jack (with piece of wood) underneath the Diff, remove the 21mm diff bushing screw and bolt FIRST(#14), 21mm socket on bolt head side, and 21mm Gear Wrench on nut side. (the pic was taken after the bolt and nut were removed.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff10.jpg
The side of the diff facing the rear of the car is tight. The GearWrench is essential for getting to the back bolts. I remember having to insert the wrench on the inside of the Ebrake cable, and then once the bolt was out far enough, you have to take the wrench off the bolt head and start again on the outside of the cable. (#15) is the right rear side bolt.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff6.jpg
(#16) is the Left Rear side 21mm bolt. Same story as the right side, and you'll want to use the 21mm Gear Wrench again. Jacking up the diff a little until the bolt is straight across helps with removal. Make sure you keep an eye on the diff when you remove the bolt, as it is the last bolt holding it in. It could wobble off the jack. When lowering the diff, it's tight getting it of the middle of the cradle. You'll have to tip the diff to one side (I did left side) so you can clear the cradle. Hold the one side of the diff with your hand (while it's tipped) and lower the jack SLOWLY watching for clearance issues. Once it's down, hold it on the jack while you pull it out from your V. ELVIS HAS LEFT THE BUILDING!!!!
http://i132.photobucket.com/albums/q16/n2havnfun2/diff7.jpg
DRINK ANOTHER BEER
After you admire the destruction of the old diff, it's time to change the axle seals on the new diff. I took a pic of my prybar inserted into underneah the axle seal itself. (#17) BE CAREFUL!! Only insert it so the prybar just touches the inside of the seal NOT THE CASE! This "awesome" diff case is ALuminum and you could score the inside lip and cause more probs for yourself. They pop out easily. Grab your new axle seals, put a little gear lube around the seal, and insert it into your new diff. Mine came with shipping plugs (thank you CTSV_Rob) so I turned them upside down and lightly tapped on the plastic plugs until the seals were seated. You can use a piece of wood, just make sure you hit in the center and make sure they are properly seated.
http://i132.photobucket.com/albums/q16/n2havnfun2/diff8.jpg
My new diff needed a vent, and you have to replace them anyways, so now it's time for that portion. (#20) shows the part I'm talking about. When you install the new vent, I used a 9/16 open end wrench around the very small lip around the base of the vent and hit the wrench with a hammer. I wasn't sure the vent could take the abuse of a hammer hit, so I used the lip to take the abuse. ewill3rd might jump in here and let us know if the vent can take a hammer hit or not. It was $19 (and dealer is across town) so I figured I wouldn't chance it.
http://i132.photobucket.com/albums/q16/n2havnfun2/diffvent.jpg
Alright, so once the diff is ready to go, get it on the jack (holding it so it doesnt tip off) get it underneath the cradle and jack it up. Once you tip it to the side and get it up there, the left side axle shaft will be in your way.
This is where the seal protector would be used while inserting the axle shaft. I did not use one, but I was EXTREMELY careful not to have the splines grind into the seal itself!!!! You are going to have to play weeble wobble with the diff on the jack in order to get the axle shaft into the diff. BE PATIENT!!! If the splines don't automatically lineup, turn the front pinion "bell" on the diff and it will turn the gears inside (thus moving the splines). Once you get the splines to match up, it's not over. You have to get the snap rings on the end of the axle shaft to "snap" back into the diff. This was a PITA. I pretty much had to manhandle the diff and axle shaft in order to "pop" it back in. ewill3rd said they use a prybar to get em back in. I was on my back and didn't have enough room between the car and the driveway to have any leverage, so I resorted to just pushing the two together. You might have to pull the jack and diff over a little closer to the axle shaft so you don't yank the diff off the jack.
Once you get the axle shaft "snapped" back into the diff, give it a good tug to be sure the snap rings have made their final resting place. You'll know when they "snap" back in.
Once that BS is over with, it's time to put the other halfshaft back in. Same process as before, but it's much easier on the right rear side since the axle shaft is just sitting there from when you removed it before.
LUVMY04V
06-20-08, 09:14 AM
Off to reeds FAQ for this :) Im not very mechanical but this is gonna help alot of people
lollygagger8
06-20-08, 10:09 AM
THIS NEEDS TO BE ADDED TO THE WRITEUP, IT WOULDN'T LET ME ADD AFTER 45 MINUTES OF POSTING. PLEASE HELP.
Now reinstall the entire right rear suspension parts you removed to get the diff out. Pretty much reverse order of uninstalling it. The pic of (#4) is where you can put the allen wrench/or drift punch into the caliper to keep the hub from moving.
Once you get it all back together, get the wheel on, tighten your lug nuts. If you are installing a used diff (like me) take the drain plug out and make sure to wipe off the metal "goo" off the magnetic drain plug. Once you've wiped it off, reinstall with your 10mm allen wrench. Now it's time to fill the new diff with your choice of Gear Lube. I used good old GM 75-90w "grape scented" (whatta joke) differential fluid, and the small bottle of Limited Slip Additive. Our diffs hold a quart and 1/4 of diff fluid. If you didn't remove the fill plug before hand, it's the same 10mm allen head wrench you used on the drain plug. Put the Limited Slip Additive in FIRST. That way you gaurantee you have room for it in the diff. You'll know it's full obviously when the fluid starts coming out the fill hole. I used a screw on to the bottle filler tube and squeezed the $hit out of the bottle. You can also use a suction gun which is probably better.
Once diff is full, reinstall the half shaft/drive shaft while tightening down the allen head bolts (#2) I think
ewill3rd told me blue loctite on these bolts. I'll ask him an edit this if that was incorrect. Now reinstall your exhaust, and let the V down off the jack stands with your jack.
Moment of truth.....start up the V, engage first gear and slowly let out the clutch. Get out on the street and go slow and listen for any sounds/creaks/bangs <-HOPE NOT.....test drive and you should be able to hear/feel if something is off. Get to operating temp and pull over and look for leaks. After a couple drives, just keep an eye on everything. Stand back and admire your work, you just saved yourself alot of $$!!!!!
If I missed anything, feel free to add. I will try and get part numbers for parts, and torque specs as well. I'll say it again, THANK YOU SO MUCH EWILL3RD!!!! You put up with my questions, and you are good people!!!! Also THANK YOU CTSV_ROB for the new/used diff. You helped a fellow V'r get back on the streets!!
And one more time just for the helluva it........
http://i132.photobucket.com/albums/q16/n2havnfun2/diff3.jpg
rand49er
06-20-08, 10:41 AM
Whoa! This thread/FAQ might get a whole lot of use in the future.
Great job ... Thanks!!!
LUVMY04V
06-20-08, 10:47 AM
Fixed for ya lolly all in one piece
18mm socket
10mm alllen wrench
8mm allen wrench
Beer of Choice
Long Pry Bar
Two Axle Seals
Vent
Spindle Nut
DRINK ANOTHER BEER
Once that BS is over with, it's time to put the other halfshaft back in. Same process as before, but it's much easier on the right rear side since the axle shaft is just sitting there from when you removed it before.[/quote]
There ya go all in one piece
lollygagger8
06-20-08, 11:27 AM
Thanks LUVMY04V! Hopefully someone can add it to the FAQ so other people can get some use out of it. Thanks guys.
thebigjimsho
06-20-08, 12:45 PM
My friend, you just went from n00b status to seasoned vet in one thread. Good work!!
thebigjimsho
06-20-08, 12:46 PM
Hey urby, I think this guy deserves a few months supporting membership...
Twitch
06-20-08, 02:50 PM
It would suck if LUV ended up getting the credit for this one :rant2:
J/K
I'm sure a bunch of us will be going back to this thread in the next few years. I'm bookmarking it.
Great work. :thumbsup:
Tony
lollygagger8
06-20-08, 02:59 PM
Ha thanks guys! Hopefully it helps more than me!
heavymetals
06-20-08, 03:00 PM
Very good writeup:highfive:
Another example of why this forum rocks....:D
lollygagger8
06-20-08, 04:18 PM
Ya. I've learned alot from this forum, and hopefully this gives a little back. Don't be afraid to tear into your V and fix $hit it yourself. Like anything, if you do it yourself, you'll appreciate that much more.
CTSV_510
06-20-08, 06:31 PM
Well I give this thread 5 stars !
Sorry if I missed it in your writeup, but how long did this take you to complete?
ewill3rd
06-20-08, 10:09 PM
Excellent write up.
My notes would be:
The park brake cable is plenty strong, the fight you have with trying to remove it and reinstall it isn't worth the effort. You could use some mechanics wire or something to hold it if you are worried about it and I wouldn't let it hang for days, but for an hour or two it should be fine.
Be very cautious with the ABS wiring, don't pry anywhere near it if you can help it. The extention on the ball joint stud trick works pretty good if you have one that reaches past the caliper.
Use blue loctite on the propshaft (drive shaft) bolts and torque in an inverted triangle pattern, first one, then the other. 44 lb. ft is the spec. Use an 18 mm box end wrench on the front propshaft bolts against the floor pan to hold the shaft and move as required. If you remove the propshaft the spec on the front is 65 lb ft and blue loctite on those as well.
Use red loctite on the rear caliper bolts. Don't put them in dry or they can work loose. The torque is 88 lb. ft. on those.
As noted, mark each fasteners location. There are different lengths and different washers, some have nuts and some don't. Mixing them up can make a mess.
I like the punch idea to hold the rotor when turning the axle nut, pure genious. I'd advise against just putting it in the bottom when loosening or tightening (depending on which side you do).
The cross pipe between caliper halves is on the bottom, it would be a shame if this pipe got damaged.
I'd recommend putting the punch (genious I tell you!) in the area between the pads. maybe pull one pin out of the caliper and remove the spring plate for more room?
I use a deep well socket that fits over the vent cap and hits the shoulder where it presses into the diff housing to install the vent.
Just slip the vent into the correct size socket as described and tap it into place with a hammer.
Lots of information, if I missed something that needs addressed just say the word.
Again... nice write up and lollygagger, you did all the work dude... I just gave you some advice to save you a little time and trouble. ;)
Jayrcr3
06-20-08, 10:39 PM
Very nice write up. I hope not to use it ever, but my V is going in Monday for diff #1 under warranty because of the whine. (36,000mi)
Has anyone tried cryo freezing a diff and ring and pinion to make it stronger? Does anyone know what is actually causing the whine?
lollygagger8
06-21-08, 03:24 PM
Thanks guys! CTS 510: In between beers, it took about 6 1/2 hours total with taking pictures and getting tools and parts together. Plus I was by myself so it would've went faster with a friend helping. ewill3rd really helped me out with tricks and tips that really helped. Thanks Bill you ROCK!!
I'll have to take a pic of the hole punch in the rotor trick too.
I wonder if Cryo freezing would make the diff too brittle? Man that would be awesome if it worked though!
Nutz
06-21-08, 11:42 PM
Below is my last PM discussion with Lollygagger...
Nutz:Oh as for the jackstand idea... unless you wear a tie to work every day or live by a $20 tool box in your laundry room, fear nothing, it's not bad at all. If you are a person with auto repair skills, you'll be sending me a message of happiness right after you swap. Once you hear the halfshaft "click" into the new diff during installation it's pizza and beer time with your buds.
Lollygagger:Hahhaha, $20 tool box in your laundry room....ahh the good old days. Alright man, I'll quit bugging you. I want to thank you many times over for your help!! Definitely gonna get some beer/pizza for this one ha
Well, was I right about this swap being not so bad???? Heck, you did it yourself! Nice work. I'm assuming your message of happiness to me was this cool post here! I didn't get any love here:sadeyes:
I like the beer of choice tool.
Gerbonium
06-22-08, 05:55 AM
:worship:Awesome writeup man:worship:
if you dont mind me asking, how much were parts? im trying to decide if getting an extended warranty would be worth it or not when i eventually get my v
thebigjimsho
06-22-08, 03:38 PM
It's two different things my man...
We appreciate the stronger casing and the effort you put forth. But until we can get that for a reasonable price, we look longingly but without any real hope for duplicating the feat. With this writeup, we have something that many of the common man will eventually need for himself. The diffs will most likely need replacement and now we have the pictorial with writeup.
Nutz
06-22-08, 08:03 PM
Misunderstanding... I'm definately not looking for love on my case!! Never ever mentioned it.
I just answered alot of pm questions for him to help him with the courage to do this changeout in his driveway. That is all.
lollygagger8
06-23-08, 09:41 AM
Ok nutz, THANK YOU TOO! :) You are right, it wasn't that bad!
I was asking nutz more about the steel diff housing, and how hard it was to install since he did it once and I think nutz told me the only "hard" part was the ball joint. In retrospect, I guess the entire hub/knuckle assy would have been "harder" ha. But thank you regardless.
Well it depends on what you can get a used diff for.....I think around around $500 is a good deal + shipping. The axles seals were around $30 for both, then 2 qts of diff oil was around $25 each (even though you only use 1 quart and a 1/4) and the lim slip additive is around $8. You still have to buy the 21mm Gear Wrench and socket maybe allen wrenches if you don't have them. I think an extended warranty is a EXCELLENT idea as long as it is a GM certified warranty from a certified dealer. (not knock off warranties from Acme Auto Sales or whatever ha) since alot of places won't honor non GM warranties.
I would've went with the steel casing in a second, but I can't afford the $$ for it. I definitely told Nutz he was a pioneer for making it though!!
thebigjimsho
06-23-08, 11:03 AM
I just answered alot of pm questions for him to help him with the courage to do this changeout in his driveway. That is all.Great stuff!!
lollygagger8
06-23-08, 03:03 PM
Here's love for your case, nutz! :)
trukk
06-23-08, 03:38 PM
Did I read this right?
TBJS loves his nut case?
BTW to Lolly, great write up. Golf clap to you.
-Chris
ewill3rd
06-23-08, 09:22 PM
Define "a lot"... because I thought I answered a lot of questions... :lol:
I think I have about a dozen PMs and maybe some emails too...
At any rate, I think I have more credit at this point than I deserve, you can have some of mine. ;)
I do admire your efforts to get that steel diff built.
Wish it could get off the ground for you.
thebigjimsho
06-24-08, 01:02 PM
-ChrisBetter get some glasses.
lollygagger8
06-24-08, 03:20 PM
Nut case = Ex girlfriend right? ha
trukk
06-24-08, 06:53 PM
I was thinking testicle sack, or steel diff case. :D
-Chris
JonCR96Z
06-24-08, 07:17 PM
How bout a steel diff sack? Possible cure for rupture due to dick hop?
lollygagger8
06-25-08, 11:32 AM
Hhahahhaa :kari2: = main cause of dick hop
lollygagger8
07-07-08, 10:20 AM
Any chance this writeup can make it to the FAQ??
lollygagger8
07-23-08, 11:32 AM
Can somebody email Reed and ask him to add this to the FAQ? Or tell me where to email him at? I'd hate for this to go to waste :)
m3driver
08-05-08, 02:02 AM
That is a sweet write up. I just found out my front diff bushing is shot. I was wondering how to pull the diff, since I have a lift this should be a bit easier!
Thanks for the excellent write up!
Marco
lollygagger8
02-02-09, 02:31 PM
If you get the extractor tool from PISINUOFF, then you don't need to remove the entire diff in order to get the bushing out. This writeup will still help with reference though
thebigjimsho
02-02-09, 10:49 PM
hmmm...
lollygagger8
02-03-09, 10:18 AM
Contemplating your next move big jim?
thebigjimsho
02-03-09, 11:25 AM
yeah...
hmmm.....
lollygagger8
02-03-09, 12:21 PM
Hmmm.......
Indeed
nmaier2201
02-03-09, 12:30 PM
Now THAT's a nice avatar lolly
thebigjimsho
02-03-09, 01:02 PM
no boobies...
lollygagger8
02-03-09, 01:34 PM
Hahhaha, thanks....I'm a big fan of chicks, chicks making out, truth or dare, and both of them combined makes for a good avatar IMO
thebigjimsho
02-03-09, 02:38 PM
Hahhaha, thanks....I'm a fan of big chicks...There's some Roethlisberger fans out there...
lollygagger8
02-03-09, 04:41 PM
^Blasphemy!^ :lol:
Ya Ben, looks like a big chick.....and no I was rooting for the 50 yr old QB Warner!
V-Love
02-03-09, 07:29 PM
I already printed it and put it in my hard folder along with everything else I've been fortunate enough to see. I recommend it for all repair threads and maintainence threads. There are quite a few. And you have them when your under the car.
Thanks for the great addition.
lollygagger8
02-04-09, 12:11 PM
Thanks V-Love!!!!
mpunklil
05-07-09, 09:00 PM
Does anybody have a torque spec on the rear differential bolts?
darkman
05-07-09, 09:48 PM
Differential Housing Cover Bolt = 21 lb ft.
Differential Ring Gear Bolt = 136 lb ft.
Differential Support Bolt = 129 lb ft.
Drain/Fill Plug = 29 lb ft.
Pinion Cage Bolt = 21 lb ft.
Pinion Flange Nut = 210 lb ft.
Pinion Shaft Coupler to Differential Flange Bolt = 63 lb. ft.
mpunklil
05-08-09, 02:16 AM
so 129 lbs ft then?
lollygagger8
05-08-09, 10:46 AM
Yes, that is correct....thanks for the specs darkman!
mpunklil
05-08-09, 01:24 PM
thanks guys, i kinda hand torqued em, but i didnt want to overtighten them ya know
lollygagger8
05-08-09, 03:33 PM
The only time I've ever used a torque wrench on my V was for the header bolts.....you'll be fine.
mpunklil
05-08-09, 05:33 PM
yeah i could if i wanted to, but its a good thing i asked...after i tightened them w/ a 24 inch breaker bar, turned out they were nowhere near 130 lbft. Im anal about using a torque wrench, i use em every day at work. Which leads me to the LOWER rear A-Arm bolt, anybody have a torque value on that? I went ahead and torqued to 130 considering same grade and size, but i want to double check....
atdeneve
05-11-09, 01:58 AM
• lower control arm to frame mounting bolt and nut - 111 lb ft
• lower control arm to knuckle mounting bolt - 129 lb ft
• lower shock mounting bolt - 111 lb ft
mpunklil
05-11-09, 02:08 AM
thanks! i was right on :)
maxspeed96ct
12-14-09, 09:31 PM
Does anyone have a new link to the pics ?
lollygagger8
12-15-09, 02:35 PM
Shitty...I moved my photobucket around...uggghhhh
If you need some pics, PM me
maxspeed96ct
12-16-09, 07:10 PM
Send me what ever you have, Im waiting for my diff to arive in the mail and then im going in. I just want to see what im up against ahead of time.
If your bored one day shoot over some pics from your install to my PM or email me dburek85@yahoo.com
Thanks
lollygagger8
03-14-12, 09:50 AM
Here's the pics.....not in order, but just follow the numbers.
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff5.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff2.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff3-1.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff4.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff7.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff6.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff8.jpg
I apologize for them not being in order, but here's the rest. If you have questions, PM me!
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff1.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff9.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diffvent.jpg
http://i132.photobucket.com/albums/q16/n2havnfun2/Differential%20Install/diff10.jpg
7YRITCH
03-14-12, 10:45 AM
Thanks Shane!
7YRITCH
03-15-12, 02:58 PM
I've taken the write-up instructions from Lollygagger with the recent uploaded pictures, added the notes from ewill3rd, as well as the torque specs, and put everything together in a nice printable PDF for your viewing and printing pleasure. Thanks again for your write up!
Carey
darkman
03-15-12, 03:14 PM
Carey
Fantastic:thumbsup:
lollygagger8
03-16-12, 03:01 PM
Carey
Looks so much better...good job!
