MARK99STS
06-14-08, 02:30 PM
Hi all,
It's been a while since I've been on the boards. Hope everyone is doing ok. The Caddy keeps getting better and better. Just to bring everybody up to speed, I am now running a 950 Holley stand alone engine management system along with a PCS stand alone tranny controller specifically for the 4T80E. The stock PCM controls all the rest of the car as normal. The motor has a Darton sleeve with forged pistons and rods, ARP head bolts and stock crank. It is good to 1000HP. I upgraded the turbo to 70-1 instead of the 62-1 I was running. I also got a Greddy Profec-B electronic boost controler that I mounted in the dash so it looks stock. I still have the Corsa exhaust.
The guy that helped me build the car decided to get a portable "Dyno Dynamics" dyno and I have partnered with him to be the operator to go to events and do tunning. Since I have the dyno at my disposal I decided to experiment. I have a 3" down pipe coming off the turbo going into a 2.5" just in front of the CAT and continuing on back through the Corsa. Turbos don't like back pressure and I know I was choking it by going from 3" down to 2.5". I was only able to get the boost up to 11.5 lbs. so I thought what if I drop the pipe right berfore it rduces and put it on the dyno. OH MY GOD what a differencce. The boost went up to 15.5 and I gained a full 73hp to the WHEELS which is about an extra 100 to the crank. I was at 410 and then it jumped to 483. That is close to 600 at the crank. I couldn't just leave that kind of power on the table so I put an electric cutout on the exhaust so I can pick up that exra 100hp with the click of a switch. Really cool! The car did a 12.25 @118mph spinning the slicks through 2nd gear. If it woould ever hook it would be in the mid 11"s(tough to do on a front wheel drive with that kind of power)
Any...... way as you probably guessed a completely blew up the tranny. It completely fused the clutch packs so I have no 1st or reverse. I rember a link to a place in NY that supposedly made a bullet proof 4t80e. Does anybody know where I can get upgraded parts for the tranny, bigger valve bodies, thicker and stronger clutches, etc.
Now that I have created a monster I would like to see it live for a while so I can enjoy it. That is my weak link right now. Any input would be appreciated.
MARK 99STS
TURBOCHARGED
MARK 99STS
TURBOCHARGED
