View Full Version : Po41 code set
capnfred
06-11-08, 12:39 PM
94 Seville STS,Now that the transmission is running correctly, I have another issue to address. I SES light is lit, the codes are P041, which has to do with cam sensor. I believe that the sensor itself is ok, I checked the output with a dvm at the ingnition module. I beleive if the input is good, and the error is still being set, then the problem is in the module. Is my thought process valid, and if so, what are the ramifications of running it like this. It has been on since my G/F owned the car, about a 1.5 years. Thanks again for all the advice and information. Also I have a A011 code set which is for the AC hi pressure switch any advice on past problems on this are appreciated.
CapnFred
