I have a 95' ETC and i have to replace the power steering pump and the radiator. I was wondering if there is anything thats tricky i may run into with either as well as any tips or tricks for the replacement would be very much appreciated.
Thanks.
chubbyranger
06-11-08, 06:49 AM
The best tip: buy a factory service manual. eBay or www.helminc.com are two sources. If you are going to do your own work on these cars a FSM is a must. Haynes or Chiltons will not cut it. For those two components I do not believe there is any special magic required other than the ability to work in very tight spaces, which is true for every N* job other than checking the oil.
Sweet thanks i will for sure do that
