Shawn4.0
06-10-08, 01:14 PM
Well the bottom of the coolant recovery tank cracked and has been leaking coolant. I repaired it temporary with JB Weld and have a new tank on order.
The problem is that, I refilled a couple times with just water till I was sure the leak was gone, and hoping to wait till I get the resevoir to add coolant. Anyways, after a decent drive, the coolant begins to boil and spill out/steam out from under the cap.
I'm thinking just a bad cap coupled with the fact the ratios in the coolant are majorly skewed towards just water, the boiling point is much lower then it should be? The car is fine when it's first started, no bubbles in that tank then, and it only starts to boil and loose coolant through boiling over/steam, etc the temp needle goes anywhere above anything other then dead center when I stopped in traffic after a while of driving (30 mins). Even then, cruising and driving is fine, just stopped. The highest temps the car saw before I realized the leak, was on that drive home, stuck behind a city bus, the temp needle raised to about 2 o'clock position. Turned the a/c off, cranked the temp to full heat and the engine temps dropped quickly.
So just grab a new cap and coolant and get the ratios right? What about the tank itself, could I use a different tank from some other model temporary at least? Realize getting the different hose sizes, correct volume, but be tough, be just something in the mean-time? Or should I have more faith in JB Weld? It appears it made it 50 mins all the way to work, so I dunno.
