View Full Version : where does this thing go (headgasket job)
lapwizrus
06-08-08, 08:39 PM
Hey guys, my head gasket project is coming along nicely and I'm in the process of putting everything back together. The heads are on, along with the crossover and the exhaust manifolds. Timing is set as well.
Here is my questions, for the life of me I do not remember where this thing goes:
http://www.andrews.edu/~vorostse/mystery-piece.jpg
Here are some engine shots
http://www.andrews.edu/~vorostse/engine_1.jpg
http://www.andrews.edu/~vorostse/engine_2.jpg
So any ideas?
tman2093
06-09-08, 08:48 AM
I can't believe noone has responded yet. Courtesy bump, as well as it looks like an exhaust shield, look around at the path the exhaust takes, specifically the crossover pipe.
ewill3rd
06-09-08, 10:00 AM
I am thinking... looks like maybe it goes close to the EGR valve somewhere?
Hmmm... what year is this?
AJ might know off the top of his head if you can find him.
Ranger
06-09-08, 12:39 PM
I was going to suggest the EGR heat shield, but wasn't sure enough.
submariner409
06-09-08, 02:14 PM
I just spent some time looking and going through the 02 FSM. No joy.
It looks like some sort of shield or safety preventer to keep a pipe or hose from popping off a fitting.
It's awfully clean to have come from outside the engine unless you scrubbed it........
tateos
06-09-08, 07:41 PM
It is an exhaust heat shield that protects the vehicle speed sensor from the heat off the right/rear exhaust manifold. I bolts to the same bolts as the right/front brace between the transaxle and the engine. I can see in your 2nd engine pic where it goes. Let me know if you need some more help
ewill3rd
06-10-08, 07:28 AM
I am pretty sure he's right. I think I do remember it going down there.
AJxtcman
06-10-08, 07:39 AM
Yes it goes over the Trans output speed sensor.
That would be on a 98 Seville correct?
http://i224.photobucket.com/albums/dd25/AJxtcman/forum/engine_1.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/forum/mystery-piece.jpg
lapwizrus
06-10-08, 08:08 AM
You guys rock.
Take a look at this.
http://www.andrews.edu/~vorostse/engine_3.jpg
Couple more weeks and she will be back on the road. Thank-you all.
codewize
06-10-08, 01:14 PM
Wow that was good. I'm impressed.
dkozloski
06-10-08, 01:21 PM
Back when I managed an aircraft engine overhaul shop, whenever we had an installation come in that we hadn't seen before we took many detailed pictures for just this very reason. It saved our bacon more than once.
