DopeStar 156
06-08-08, 08:11 PM
It sounds like it's coming from the air pump, is there a way to quiet the thing up?
| View Full Version : Squeaky Belt? DopeStar 156 06-08-08, 08:11 PM It sounds like it's coming from the air pump, is there a way to quiet the thing up? Slacker 06-11-08, 11:16 AM Is the belt loose and slipping or very worn? DopeStar 156 06-11-08, 12:45 PM It's not slipping or loose, there's just a squeak when the car runs. NYJets53 06-27-08, 11:19 AM Try a new belt...inexpensive carnut 06-29-08, 11:22 PM Belts squeak when they are worn out, glazed, misrouted or wrong for the application. Belt dressing is not a fix, its a diagnostic tool. Applying belt dressing will confirm a faulty belt rather than a faulty bearing. Over the years, I've used a bar of hand soap applied to the bottom side of the belt to verify a belt caused noise. Slacker 06-30-08, 02:49 AM Belts squeak when they are worn out, glazed, misrouted or wrong for the application. Belt dressing is not a fix, its a diagnostic tool. Applying belt dressing will confirm a faulty belt rather than a faulty bearing. Over the years, I've used a bar of hand soap applied to the bottom side of the belt to verify a belt caused noise. 2nd that. I spray some PB blaster on the belt (b/c it's not really that flamable, you can shoot it into a propane torch and it won't ignite). If it stops for any period of time, it's the belt. Tighten if wobbly, replace if worn. DopeStar 156 07-01-08, 12:41 AM Ahh cool. I'll have to pick up a new belt then. Thanks. | |
