bpeesy
06-03-04, 07:47 PM
I have a 1978 Fleetwood, I'm having headlight issues. All lights work except the headlights. I dont show a headlight fuse anywhere. Any ideas what to do next? I dont get anything from the low or high beams.
| View Full Version : head light problem bpeesy 06-03-04, 07:47 PM I have a 1978 Fleetwood, I'm having headlight issues. All lights work except the headlights. I dont show a headlight fuse anywhere. Any ideas what to do next? I dont get anything from the low or high beams. caddydaddy 06-03-04, 10:16 PM Check the floor dimmer switch! On my '79 Deville, water had gotten down into the connector and shorted it out, melting the wiring to the switch. I then installed a new switch, and used heat shrink tubing to seal any water out. Good luck! Dead Sled 06-04-04, 01:25 AM theres a fuse there somewhere like others have said check the dimmer switch the headlight switch usuall dont go bad with out you feeling it in the knob bpeesy 06-04-04, 01:22 PM I checked all the fuses, they all seam to be good. Where would I find the Dimmer switch. Is it the thing on the floor that you step on to turn the bright lights on with? caddydaddy 06-04-04, 02:05 PM Yep! That's the one! It's held down with two screws. They are only $12 or so to replace, so hopefully that's your problem. Good luck! | |
