View Full Version : Progress of engine swap
csbuckn
06-07-08, 02:24 AM
Swaping the 307 SBO for a 305 SBC(it was free). I have decided to keep it carbed because it seems alot easier.
So I have took the engine out(305 from donor), drained it, took it down to the headgaskets, cleaned it, painted it and am putting it back together now.
The questions I have are:
Should I do the rod bearings if the engine ran just fine? I was just gonna do gaskets.
Also, What kind of carb/intake setup should I go with for a daily driver? I have never did any carb work before and want something that can bolt up really easy. Some of the intakes i have looked at dont seem to have a spot for EGR, Do I move it somewhere? I just want this to be as easy as possible since its my first engine swap and the Caddy is my baby. Please help
jayoldschool
06-07-08, 11:44 AM
Go with the Edelbrock Performer (you can get it with EGR) and an electric choke Edlebrock 600. You will be very happy with how it runs.
deVille33
06-07-08, 10:48 PM
Wait a minute Buck. Have you really checked this out? From what I recall the 307 & 305 have different bolt patterns per trans mount application, unless they changed things in later engines. Are you changing engines & transmissions? What year is that 305? If it isn't up to date for that '90, it may not pass emissions, if required in your state. Last conversion I did turned into a continuing run to the pick-a-part for items needed in order to bring the engine up to the standards for the year model of the car.
jayoldschool
06-07-08, 10:50 PM
We've been through all this swap advice already... check his other thread...
deVille33
06-07-08, 10:54 PM
Oh. I just take 'em from the top to the bottom. :banghead:
