wrgr84
06-06-08, 08:43 PM
Help !!! I have a 97 , Replaced compressor , drier , orfice tube , all o-rings rechared 32 oz freon and compressor will not kick in . I can run wire direct abd it will but not threw system . I have 2 codes coming up on PCM , Service A/C and A/C compressor off . I have tried to reset the PCM , it will not reset.
Connected Modis to it reset all codes did not change , same codes come up . Disconnected battery for 5 minutes did not work ,
I keep hearing you have to reset the PCM , But everytime I try it will not reset .
Any suggestions ????
