View Full Version : Half case leak check
STS 310
06-03-04, 01:54 PM
Is there an easy way to look for leaks at the problematic points? Going to check out an STS tommorow at a small lot and i want to make sure the case is not leaking.
should i try and look under the engine or feel for oil or what?
eldorado1
06-03-04, 06:55 PM
Pretty much. I'd be suspicious if it was clean and bone dry - drive it around a little (lot) and then check it. Any grime or buildup can potentially indicate a problem as well. Any oil (obviously) means a current problem.
