: Air pump switch
06-03-08, 08:49 PM
I have an 03 EXT. Can anybody tell me where this switch is that activates the air pump to keep me level. Im saggin in the back and the pump isnt coming on any more so I want to check the switch and the pump and what ever else needs checkin. Thanks for any help GJ
06-03-08, 08:55 PM
As far as I know, there is no switch. It sounds like your compressor may be shot.
06-03-08, 10:34 PM
The switch is on the left rear trailing arm. You will see a link from the arm to the lever on the switch. Check the fues for the system if not blown it most likley needs a compressor. They are very common.
06-04-08, 04:53 AM
Thanks for the help I will find the switch
06-05-08, 01:02 PM
mine was not coming on either and I was told the 40 amp fuse was blown. Once replaced it was working again. I just wish I knew where that fuse was located in case it ever happens again.
06-06-08, 08:23 PM
I must be a butt head I cant find the switch. Where is it located from the pump which is just behind the left shock. And where is the fuse for that system? I couldnt find it on the fuse chart. Thanks for any help. GJ
