CJPC
05-29-08, 08:40 PM
Been quite a while since I have posted, but I will get right into it.
Did a tune-up on my 92 Brougham (5.0), new plugs, new wires, new distributer cap, new rotor, air filter. Have not had a chance to install the fuel filter yet.
Cut to today, I finished up installing the wires, low and behold there are issues.
Of note, the plugs are pre-gapped, not to regap etc.
The car starts without any issue, but then starts to chug for about 10 seconds (sounds like it wants to die out). Then the engine runs smooth (very quiet, quieter than before), and my Service Engine Soon Light pops up.
I double checked the firing order, and it is spot on (although when it is light out, I am going to recheck it yet again).
The code pulled from the Dash is error 33 - Map Sensor Circuit Low Vacuum.
I have yet to attempt to disconnect the MAP sensor to see if the issue clears up (again, when it is light out). But was wondering if anyone ran into a similar issue?
I did a search - turned up nothing concrete. But those rear passenger side plugs are a pain to get at due to the AC compressor, my arm is all cut up!
But if anyone has any insight, it would be appreciated!
Thanks,
CJ
Edit: was a bit dark out, but I disconnected the electrical to my MAP sensor, and the car started without any sluggishness. I take it either the sensor is hosed, or the vacuum line is busted?
Thanks,
CJ
