kdybread
06-02-04, 07:27 PM
I have a 1995 SLS and lately everytime I start it up after it sits, it takes at least 5-6 seconds to start up...it starts, but something definitely ain't right. Any suggestions, similar probs?
| View Full Version : HELP! 5-6 sec. Cold Starts kdybread 06-02-04, 07:27 PM I have a 1995 SLS and lately everytime I start it up after it sits, it takes at least 5-6 seconds to start up...it starts, but something definitely ain't right. Any suggestions, similar probs? zonie77 06-02-04, 11:42 PM Did you check the fuel pressure regulator? Daddytech 06-03-04, 02:14 AM i am still trying to figure out the 3 minute pause my Eldorado put me through only days after purchasing it. the car sat for one day after i bought it , i went out to go to work, put the key in the ignition, turned the key and nothing all dash lights came on as usual, but that was it, i tried it two or three more times immediately after that and was then greeted with a message on the dash telling me to wait 3 minutes. i watchted the time on the dash count down and after the 3 minutes got another message telling me to "Start Car". I turned the Key and it started right up and hasn't done that again since then. not sure why it happened that way. It still has me scratching my head. :bonkers: CadiJeff 06-03-04, 03:04 AM daddytech that is the passkey 2 system, since it only happened once your key was either wet or dirty. don't wory it isn,t a problem unless it does it all the time RBraczyk 06-03-04, 07:21 AM Check your fuel pressure, Ignition coil, plugs wires that stuff, And if those all check out, you need a new starter. STS 310 06-03-04, 01:50 PM Fuel pressure reg or fuel pump are culprits | |
