FromTheKing
05-28-08, 06:21 PM
i have a 94 eldo. the oil sending housing has 2 O-Rings in side....
the dealer sold me 1s that were 2 big and were a soft rubber O-Ring...
mine are about 7/8 outside diameter and made of a hard plastic O-Ring
so i had him order more to see if he had the wrong part.....and the same 1s came in(way 2 big 4 my car)... :rant2:
any help would help......thankx in advance :worship:
Gordon..............
Edahall
05-28-08, 07:34 PM
Mine was leaking at the same spot so I went to Harbor Freight and bought their O-Ring set sold in a bulk of about 20 different O-Rings and about 100 in quantity. I cost me about $5 and I was able to find an O-Ring from the set that matched. When you tighten down the fitting, make sure you don't over tighten.
FromTheKing
05-28-08, 08:10 PM
rotf....
thats whats in it now (a harbor freight soft rubber from a big kit )and its still leaking...
soft rubber gasket??
but the 1 that came out was hard plastic...........
eldorado1
05-28-08, 09:11 PM
He might be giving you the o-rings for the lines, not the oil filter adapter to block interface.
The oil filter adapter to block o-rings on my '97 were round in profile, rubber like and around 7/8" in diameter. Maybe the ones on your engine became hardened over time?
FromTheKing
05-28-08, 10:37 PM
being old my guess would be they sould be brittle (salty winters) not hard...
thinking these gaskets were molded this way...
why would the dealer part be bigger ?
but worse case i guess i try this again
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2901
AJxtcman
05-28-08, 10:55 PM
What color are they and how many bolts did you remove to get the housing off the car. Did you have to remove 2 lines?
FromTheKing
05-30-08, 08:38 PM
2 bolts....2lines(dont have to remove lines)
but i had the dealer check a 93..... :want:
and sure as shit.... there was a diff part # :suspect:
i hope to see them tomorrow.... :thumbsup:
crossing my fingers................... :bigroll:
