Roswell256
06-02-04, 02:43 PM
I have yet again had to have the Caddy towed. This time it was a bad Alternator.
I'm wondering if I'm still playing catch up from letting it sit for a year. I'm replaced water pump, Coolant feed/return pipes for heater, T-Stat, A/C clutch/coil, Alternator, Plug wires, resealed intake after removing Rat nest.
I've started to notice that my transmission fluid was high the other day. I stopped to check fluids. After driving for about 40mi. When I pulled the dipstick. it was wet all the way up to the bottom of the cover. and you could see the fluid was higher then it ususally was. Wonder if this could be a problem, or if it was the shop that did the alternator just topping off fluid levels
I guess we'll see whatelse blows up on my car. Hopefully nothing, but last time I said it was running great. It died.
Thanks
-Roswell-
Thanks
-Roswell-
