ls1z4me
06-02-04, 02:19 PM
Hello all,
New to the forum and to owing a 98 STS. I just got the car at auction with 72K on the clock. I have really enjoyed the car so far but I have already encountered some problems.
The water pump was leaking so I replaced that this Saturday and flushed the cooling system.
Also the engine had a miss at idle. First I ran a take of 91 with Chemtool fuel system cleaner, but no change.
I have read every post about idle or hesitation problems. After an inspection of the plugs and wires the appear to be new and a good shape. The plugs are the correct Delco gaped at.050, and the wires are aftermarket carquest brand. Note that 2,4,6,8 plugs were very clean and looked like new. I have only removed and checked # 3 on the starborad side becuase I saw that wire boot was not flush with the cam cover. It looked normal.
Fuel pressure regulator does not appear to be leaking when the vac, hose is removed. The #2 injector looks newer then the rest.
In a post from last year a member said that he his misfire turned out to be caused by a leaking head gasket, and that it was leaking just enough to cause the misfire at idle. After reading this I remembered how clean the plugs looked on the port side of the engine. I started to think that I may have a gasket problem.
Can anyone give me some advice on this theory and how prove or disprove it?
I also found out today from reading the post here that I have a bad motor mount. I had the wife rev the engine in drive and the passenger front came up about an inch. NAPA say they can order them in, but not sure on which one to order.
Any advice here would be great also
