Bluesteele07
05-26-08, 02:54 PM
Trying to work my way through the electrical system on this. Everything works fine except the actual "start" position. Am using the electrical diagram from the Haynes book and right now am trying to find the "Starter Enable Relay" to check it. Am inside the fuse/relay compartment left side of the engine compartment, but the "map" inside the cover does not list a relay that is called the "Starter Enable Relay" or anything that seems to relate to the ignition system.
Any suggestions on a quick/easy way to check continuity across the Park/Neutral position switch would also be welcome! I've got a digital multimeter and most necessary tools.
Thanks in advance!
Thanks in advance!
