ibiza1010
05-23-08, 02:08 PM
I have an 08 CTS with the Bose Amp and Navigation System and wanted to add an aftermarket subwoofer and amplifier to replace the stock subwoofer in the rear decklid.
I used a JL Audio A1400 amplifier (340 watts @ 4ohm) connected to a JL Audio Powerwedge CS112RG-W3v3 subwoofer enclosure. The enclosure fits nicely under the rear decklid in the trunk and doesn't take up too much room. The enclosure has 1 - 12 inch W3v3 subwoofer rated up to 500 watts. I also utilized an MTX Re-Q module to provide a remote turn on sense for the amplifier and also to supplement the loss of bass in the stock Bose equalization scheme.
The stock Bose amplifier is located in the driver's side rear trunk area in the opposite side of the stock battery location. To get to the amplifier you unscrew the 2 black plastic cargo retainers and pry out the two black plastic trim "plugs" with a flathead screwdriver on the driver's side trunk carpet area. Then pry the two black plastic trim pieces surrounding the metal cargo hooks in the lower black plastic piece below the trunk opening. Once the two trim pieces are removed surrounding the metal cargo hooks you can pull directly up on the black plastic piece covering the trunk latch and it will easily remove. Now, you can fold the trunk carpeting covering the amplifier forward towards the rear seats. The Bose amp has 4 plugs (see attached picture) and the plug nearest the rear of the car is the one you need to splice into for the Sub output signal. The line-level signals from the Bose amp are not amplified (there is a separate amp for the subwoofer in the cargo shelf area), the Subwoofer + signal is the Blue with White stripe wire. The Subwoofer - signal is the Light Green with Black stripe wire.
The MTX Re-Q supplies the amplifier turn-on wire (typically blue) by monitoring the signal coming off the front full range speaker signals. Left Front full range door + signal is Tan, - is Gray. Right Front full range door + signal is Light Green, - is Dark Green. 12V Constant and Ground are wired directly to the battery in the trunk.
The stock subwoofer is disconnected but still in the stock location.
The additional bass provided by the aftermarket subwoofer and amp is powerful but not overpowering. I found the addition to be worthwhile and fairly easy to install. The hardest part was researched the stock wiring codes.
Let me know if you have any questions.
