: Rear deck speaker for 05 CTS
05-22-08, 08:53 PM
What is the size of the rear deck speaker for a non Bose system and also the size of rear deck for a Bose system.
I looked through Crutchfield and only found front and rear door speaker sizes.
Any suggestions for speaker options while keeping the factory head unit.
thanx stillen
05-24-08, 07:21 PM
I believe it a 10'' sub in the back with Bose system having two of these and a different ohms as well
05-26-08, 03:35 PM
Only one 10" and it just under so if you use an Infinity 10" you will need to remove some material from the ID to make it fit.
05-27-08, 08:46 AM
keep in mind you can use a 2ohm DVC sub and wire it down to 1ohm just like the bose unit.
