: Northstar head bolt torque - and later update
jeffrsmith
05-20-08, 09:55 PM
I have been reading up in my FSM in preparation for doing the HGs on my 99 SLS and as has been reported here in the past there is a discrepancy in the torque values in the different sections of the manual. Can someone clear up what is the "better" values to use? I have been reading in other posts to try to figure this out but I still have the question.
The manual states in the spec section (6-9) and then again in the Cylinder Head Installation (6-222) to torque to 30 lb ft, then 70, 70, 60 for a total of 200 degrees.
Then the manual states in the Cylinder Head Replacement procedure (6-111) to torque to 22 lb ft, then 60, 60, 60 for a total of 180 degrees.
Then I read in the 97 ETC Head Gasket Replacement thread that some people torque to 30 lb ft, then 60, 60, 60 for a total of 180.
Which specification should I/we really be using? I want to make sure I get it right.
Jeff
RickyHenry
05-21-08, 11:55 PM
Jeff
Engine - Cylinder Head Tightening Specs Clarification
File In Section: 06 - Engine/Propulsion System
Bulletin No.: 99-06-01-016
Date: October, 1999
SERVICE MANUAL UPDATE
Subject:
Cylinder Head Tightening Specification Clarification
Models:
1993 Cadillac Allante, Sixty Special (FWD)
1993-96 Cadillac Fleetwood
1993-99 Cadillac DeVille, Eldorado, Seville
1994-99 Cadillac Concours
1995-99 Oldsmobile Aurora
with 4.0 L or 4.6 L Engine (VINs C, Y, 9 - RPOs L47, LD8, L37)
This bulletin is being issued to clarify the cylinder head tightening specification listed in the following procedures in the Engine Mechanical 4.0 L and 4.6 L sections of the appropriate Service Manuals:
^ Specifications - Fastener Tightening Specifications
^ Cylinder Head Replacement - Installation Procedure
^ Cylinder Head Installation
The torque specification and sequence for the cylinder head bolts (1--10) using J 36660-A is:
1. First Pass - 40 N.m (30 lb ft)
2. Second Pass - 70 Degrees
3. Third Pass - 60 Degrees
4. Fourth Pass - 60 Degrees (190 Degrees total) The torque specification for the three front M6 cylinder head bolts is:
12 N.m (106 lb in)
jeffrsmith
05-22-08, 06:19 PM
Thank you RickHenry
tateos
05-22-08, 09:35 PM
I did my left head 22 60-60-60, then I thought I read 30 60-60-60, so I did the right 30 60-60-60, and left the left head as is. No problems so far.
RickyHenry
05-22-08, 11:16 PM
well, if one goes first, maybe we can finally settle this debate. You have setup a nice controlled testing environment.
btw, i did both of mine 30 60-60-60, then later found in another section of the service manual completely different specs. Confused the hell outa me. I'm not about to pull the engine again to adjust to proper specs, i'll just play the waiting game.
tateos
05-23-08, 03:13 PM
Right - that is what I did - left it alone and hoped for the best
20grand
06-22-16, 06:52 PM
Are these specs good for 2000+ models?
Submariner409
06-23-16, 01:17 PM
The old torque + degrees sequence for the 1996 - 2003 Northstar is as follows, but read on.............
First pass - 30 lb/ft
Second pass - 70 degrees
Third pass - 60 degrees
Fourth pass - 60 degrees
for a total of 190 degrees
BUT ..............
Please read the "Important" paragraph at the bottom of P.6 in the link in Post #1 - (Engines; Northstar stickies).
Degree sequence modified in 2006 ............. and use NEW GM head bolts in the inserts - NEW.
It is now 30 lb/ft + 70 - 60 - 45 degrees for a total of 175 degrees.
http://www.cadillacforums.com/forums/northstar-engines-system-technical-discussion/198220-northstar-ring-cleaning-procedure-proper-oil.html
