KenD245
05-20-08, 02:59 PM
I would like to tow a small boat with my CTS. Where can you get a tow hitch and how much weight can you tow safely?
| View Full Version : What can you tow with your CTS? KenD245 05-20-08, 02:59 PM I would like to tow a small boat with my CTS. Where can you get a tow hitch and how much weight can you tow safely? Zymurgy 05-20-08, 06:04 PM From pages 4-30 to 4-42 of the Owners Manual: How heavy can a trailer safely be? It should never weigh more than 1,000 lbs (450 kg). But even that can be too heavy. It depends on how you plan to use your rig. For example, speed, altitude, road grades, outside temperature and how much your vehicle is used to pull a trailer are all important. It can also depend on any special equipment that you have on your vehicle, and the amount of tongue weight the vehicle can carry. See “Weight of the Trailer Tongue” later in this section for more information. Maximum trailer weight is calculated assuming only the driver is in the tow vehicle and it has all the required trailering equipment. The weight of additional optional equipment, passengers and cargo in the tow vehicle must be subtracted form the maximum trailer weight. You can ask your dealer/retailer for our trailering information or advice, or you can write us at our Customer Assistance Offices. See Customer Assistance Offices on page 7-5 for more information. Weight of the Trailer Tongue The tongue load (A) of any trailer is an important weight to measure because it affects the total or gross weight of your vehicle. The Gross Vehicle Weight (GVW) includes the curb weight of the vehicle, any cargo you may carry in it, and the people who will be riding in the vehicle. If you have a lot of options, equipment, passengers, or cargo in your vehicle, it will reduce the tongue weight your vehicle can carry, which will also reduce the trailer weight your vehicle can tow. And if you tow a trailer, you must add the tongue load to the GVW because your vehicle will be carrying that weight, too. See Loading Your Vehicle on page 4-22 for more information about your vehicle’s maximum load capacity. If you are using a weight-carrying hitch, the trailer tongue (A) should weigh 10 to 15 percent of the total loaded trailer weight (B). After you have loaded your trailer, weigh the trailer and then the tongue, separately, to see if the weights are proper. If they are not, you may be able to get them right simply by moving some items around in the trailer. Total Weight on Your Vehicle’s Tires Be sure your vehicle’s tires are inflated to the upper limit for cold tires. You will find these numbers on the Tire-Loading Information label. See Loading Your Vehicle on page 4-22. Then be sure you do not go over the GVW limit for your vehicle, including the weight of the trailer tongue. Hitches It is important to have the correct hitch equipment. Crosswinds, large trucks going by and rough roads are a few reasons why you will need the right hitch. Here are some rules to follow: • The rear bumper on your vehicle is not intended for hitches. Do not attach rental hitches or other bumper-type hitches to it. Use only a frame-mounted hitch that does not attach to the bumper. • Will you have to make any holes in the body of your vehicle when you install a trailer hitch? If you do, then be sure to seal the holes later when you remove the hitch. If you do not seal them, deadly carbon monoxide (CO) from your exhaust can get into your vehicle. See Engine Exhaust on page 2-47. Dirt and water can also enter the vehicle. Safety Chains You should always attach chains between your vehicle and your trailer. Cross the safety chains under the tongue of the trailer so that the tongue will not drop to the road if it becomes separated from the hitch. Instructions about safety chains may be provided by the hitch manufacturer or by the trailer manufacturer. Follow the manufacturer’s recommendation for attaching safety chains and do not attach them to the bumper. Always leave just enough slack so you can turn with your rig. And, never allow safety chains to drag on the ground. Trailer Brakes Does your trailer have its own brakes? Be sure to read and follow the instructions for the trailer brakes so you will be able to install, adjust and maintain them properly. Because you have anti-lock brakes, do not try to tap into your vehicle’s brake system. If you do, both brake systems will not work well, or at all. Trailer Wiring Harness All of the electrical circuits required for your trailer lighting system can be accessed at the driver’s side rear lamp connector. This connector is located under the carpet on the rear corner of the trunk compartment. omegafiler 05-20-08, 06:12 PM Basically, don't tow with a Cadillac CTS. :) carterb 05-20-08, 07:29 PM Basically, don't tow with a Cadillac CTS. :) That's what they make trucks for ....:thumbsup: ddawson 05-20-08, 09:09 PM Shame on you. No towing with the 08 CTS,Motor Trend's Car Of The Year. It is too beautiful. Southern 05-20-08, 11:46 PM If you are very careful, you can buy a Jet Ski and trailer tht will go about 800 pounds. You can probably find a 14-15' sailboat (like a sunfish) that with trailer would be abput 600 pounds. But like the Owners manual points out.......you don't want to do thisin mountains. Other than a 14' boat ith <>20HP Outboard, I don't see a powerboat capability here russj262 05-21-08, 03:53 PM I to am looking to add a trailer hitch to my CTS. I have a stand-up JetSki on a small trailer which weighs maybe 600lbs. I hate driving my SUV to the lake (where the JetSki is stored) only to need it for 10 minutes to put the JetSki into the water. This would also be great for my hitch mounted bike rack. My biggest concern is the ugly square tube hanging behind the car. From what I have seen both Draw-Tite and Hidden Hitch both have tow hitches for the 2008 CTS. http://www.hiddenhitch.com/ http://www.drawtite-hitches.com Russ Jones | |
