View Full Version : Dash Detailing tips wanted
thepiazza
05-19-08, 10:45 PM
I was just wondering what everyone was using to detail the leather-like dash as well as all the similar pieces on the doors?
Daniel Cadillac
05-20-08, 03:13 AM
I detailed high-end vehicles for 2-years w/ my best friend (Owner of the company) and I am a firm believer in Meguiar's products. For the synthetic material used on the dash, door panels and etc., I would recommend Meguiars #40 (Vinyl and Rubber Cleaner/Conditioner). I would recommend you use it on all interior surfaces except the leather seating and of course, the obvious (Chrome, aluminum, wood trim, etc.).
It's been a while since the website was updated but just so know I'm not bluffing. www.EliteDetails.com
Brooks
05-20-08, 09:37 AM
Nice Website, but nowhere does it say what city or state you're in to see if I could use you. I could try and find the area code on a map or pay for a long distance phone call, but where are you located. Thanks
C&C
05-20-08, 12:11 PM
ProtectAll is a fine product that can be used for a variety of surfaces. It doesn't sheen like ArmourAll and others, which is a good thing. And to just get the dust off I use the small California Duster (hand mop like device that works well).
cts2008lover
05-20-08, 12:56 PM
Clear baby oil is used sometimes.
Daniel Cadillac
05-20-08, 04:18 PM
Yeah, like I said, we need to update the website. :)
We service all of the greater Sacramento, CA area. :highfive:
Nextone
05-20-08, 11:50 PM
After doing some research on some auto detail sites a couple of years ago, I decided to try "303 Aerospace Protectant". I use it on interior and exterior vinyl and plastic. Great UV protectant, restores the luster without being too glossy or tacky. Try Googling it for reviews. By the way, your local retailers may be limited to boating stores, but I was also able to find it at Ace Hardware. Yes, I use it on my 2008 CTS dashboard. Just my two cents worth.
greyghost04
05-21-08, 02:09 PM
Does everybody on the board still not like Amourall?
C&C
05-21-08, 05:02 PM
Not on the dashboard. It it hazardous when driving into the sun; it reflects too much, creating glare.
omegafiler
05-21-08, 05:25 PM
I've always gone the GM route for all interior cleaning...
Interior - Cleaning of The Interior Surfaces
Bulletin No.: 06-00-89-029D
Date: January 10, 2008
INFORMATION
Subject:
Interior Cleaning - Instrument Panel (IP) Hard or Plastic Surfaces Seats Carpet Leather Vinyl Fabric Cleaner Stain Remover Restorer - Product Availability
Models:
2006-2009 GM Passenger Cars and Trucks including Saturn
(EXCLUDES Cadillac DTS with RPO R9N - Tehama Leather)
2006-2009 HUMMER H2, H3
2006-2009 Saab 9-7X
Supercede:
This bulletin is being revised to update the model years. Please discard Corporate Bulletin Number 06-00-89-029C (Section 00 - General Information).
To keep the vehicle interior looking the best it should be cleaned often. It is important to keep the upholstery from becoming heavily soiled. The vehicle's interior can experience extreme heat which can cause stains to set quickly. Lighter color interiors may require more frequent cleaning. Care should be taken because newspapers and garments may transfer color to the vehicle's interior.
Many of today interiors are made with new low gloss materials. Permanent damage may result from using cleaners on ANY surfaces (interior trim instrument panel carpet leather vinyl and fabric) for which they are not intended. Using non-approved products can actually set the stain to the point that nothing can remove it.
Do not use silicone or wax-based products or those containing organic solvents (such as naptha, alcohol, etc) to clean your vehicle's interior because they can alter the appearance by increasing the gloss in a non-uniform manner. The increase in gloss may cause annoying reflections in the windshield and even make it difficult to see through the windshield under certain conditions.
Never use a STIFF brush or a brush that has been previously used with a harsh chemical. This can cause damage to the vehicle's interior surfaces.
Use only mild, Neutral-pH cleaners. Avoid laundry detergents or dishwashing soaps with degreasers. Using too much soap will leave residue that leaves streaks and attracts dirt.
Because it is critical to use only mild neutral-pH cleaners General Motors has approved the use of the cleaners and conditioners listed in this bulletin for the cleaning of interiors. These products are in the neutral-pH range and will maintain the best vehicle interior appearance. These products are water-based biodegradable and do not contain bleach solvents or harsh chemicals.
Interior trim pieces on new vehicles as well as service components arrive with a protective film. when removing the protective film adhesive residue may be left on the trim panels/components. The cleaner (for leather vinyl plastic and interior paint) is an effective cleaner in removing adhesive residue without causing damage to the component.
If soapy, alkaline cleaning solutions are used on fabrics, and not thoroughly rinsed out, the residual left in the fabric will attract dirt. Because the recommended cleaners/conditioners are in the pH neutral range, they won't leave behind soapy residue.
On heavily stained or difficult to clean fabric/carpet, it is recommended that the entire surface be treated and cleaned vs. spot cleaning. Refer to Extractor Machine and Concentrate section of this bulletin for more information.
Effective cleaning steps for hard and/or plastic surfaces:
Using a clean towel apply/spray cleaner - leather vinyl plastic interior paint directly onto the towel.
Wipe the surface with the towel/cleaner.
If necessary use a soft bristle brush to work cleaner into the crevasses of the area being cleaned.
Wipe off any excess cleaner from the surface.
Using a clean towel apply/spray the conditioner (leather vinyl restorer) directly onto the towel.
Wipe the conditioner onto the previously cleaned area to restore the material to it's original luster.
Today's interiors are developed and intended to have a low-gloss appearance. It is important to use only products which provide a low-gloss finish in order to maintain the interior's integrity, customer appeal and satisfaction.
Effective cleaning steps for fabric:
Remove any residue by lightly rubbing the surface with a clean towel.
Choose the appropriate stain remover based on the stain type.
Spray and lightly brush the area with a clean soft bristle brush.
Gently blot up the stain.
On upholstery/carpet the use of a fabric protector can help to reduce or eliminate future staining.
http://www.cadillacforums.com/forums/attachment.php?attachmentid=42187&stc=1&d=1211401393
http://www.cadillacforums.com/forums/attachment.php?attachmentid=42188&stc=1&d=1211401393
When cleaning upholstery and carpet stains ONLY the cleaning chart shown will help you determine which cleaner/formula works best on a particular stain. The chart lists many of the common stains. Some complex stains may require the application of both stain removers one after the other to remove both food-based oils and synthetic oils.
A soft bristle brush (P/N 88861425) should be used to safely work the cleaner into the leather grain or material. This enables the dirt/stain to be completely removed from the material.
Leather Conditioner/Restorer
A Leather Conditioner/Restorer is also available. The restorer is safe for all vinyl and leather. It is a water-based product and contains essential emollients to restore suppleness conditions and adds luster without adding gloss. The restorer will also provide protection against restaining.
Dye Transfer: Dye transfer will happen any time a natural fiber like cotton silk wool or suede comes into contact with leather. The lighter the leather color the more quickly the dye transfer will appear. Leather should be cleaned on a regular basis so that the dirt and grime do not adversely affect the top coat of the leather. After cleaning the leather it is important to treat the surface with the restorer.
The concentrate may not yet be available for Saab and/or Saturn Dealers. The product can be obtained from a General Motors dealership until such time it is available through Saab and/or Saturn Parts Departments.
For difficult to clean materials or when cleaning a large area the best results will be achieved when using an extractor machine and concentrate. General Motors offers the Ruby Extractor (P/N 627-CC-3000AU) through GM Tools and Equipment and has recently released a concentrate for use with the extractor machine.
Whichever extractor machine is used it should meet the minimum specifications of the Ruby Extractor:
Ruby Extractor Specifications:
Pump PSI: 55
Water Lift: 85"
Hose Length: 10 ft
The Ruby Extractor also comes with a 6 year Outer Body and 3 year Parts warranty.
Extractor: The Ruby Extractor machine was designed for automotive use and works effectively in the vehicle's interior. The narrow design of the vacuum head allows detail work in tight areas. The water pressure pump is reduced so the fabric surface is not wet more than is necessary. The dry time is greatly reduced due to less water on the fabric surface, the vacuum head making better contact with the surface and the significant water lift capability of the machine.
Concentrate: The concentrated extraction cleaner is engineered with lower pH levels to help remove alkaline buildup on fabrics. The concentrate should be mixed according to the instructions listed on the container. The available concentrate helps to break the stain down and then the stain is easily removed with less water. The concentrate used in the Ruby Extractor is slightly acidic to remove soap and alkalinity from the fabric surfaces left behind by using improper soapy solutions. Dirt grease and grime are more easily removed when the proper solution is used during the extraction process.
http://www.cadillacforums.com/forums/attachment.php?attachmentid=42183&stc=1&d=1211400981
http://www.cadillacforums.com/forums/attachment.php?attachmentid=42182&stc=1&d=1211400981
http://www.cadillacforums.com/forums/attachment.php?attachmentid=42185&stc=1&d=1211401239
http://www.cadillacforums.com/forums/attachment.php?attachmentid=42186&stc=1&d=1211401239
bobber
05-21-08, 07:29 PM
Wow, that is a reply!
Thanks for all the info. :thumbsup:
ngiardina
05-21-08, 09:48 PM
Someone needs to give Tocco Magico a try. Aerosol, no wiping, semi gloss, smells incredible. I know where to get it if you want to try, but it s like $10 a can.
voodoodr
05-21-08, 11:34 PM
Hey Daniel
I'm in Sacramento too. When will you finish the "services" page of the website? The cars look great, but a list of services/packages/prices would help a lot!!
Lee
Daniel Cadillac
05-22-08, 12:15 AM
Hey Daniel
Lee
The owner of EMD, Brandon Sessions, has been a very busy man! I have no idea when he is going to update the website but hopefully, it will happen soon. I haven't worked w/ him for about 2.5-years because I joined the military and he is now a certified EMT working to become a fire fighter.
Your best bet would be to call him at the number listed on the website and ask. It really depends on the vehicle's 1) Condition 2) Color and 3) Size.
