View Full Version : Just put 24" dub esinem floaters on - rubbing on rear passenger side. why??
mnext02
05-16-08, 12:35 PM
tires are 305 35 24
I hear rubbing when I turn on the right rear passenger side.
Why is this?
I didnt think 24s would have rubbing issues.
thanks
mnext02
05-16-08, 12:35 PM
oh its 02 ext by the way
DLE
05-16-08, 12:43 PM
There will be rubbing! You just have to do minor cuts on the fender well, or zip tie method to pull the plastic back to give the tires clearance when turning. Both my trucks on 24s rubbed until i did that. Its cleared 98%, but still rub when I go FULL turn.
ZX_man
05-16-08, 02:55 PM
As DLE said there will be rubbing. My g/f had the same problem on her EXT when we put the 24's on. Look at the black plastic well liner and locate the area rubbing. Should be two locations that are rubbing. Cut away the areas and you should be good.
Walter
