View Full Version : 02 escalade w/eclipse avn2454,speed sensor ,question!
bosanci28
05-15-08, 07:08 PM
i have a eclipse avn 2454 and i have the speed sensor wire ,,but where exactly this should go to what wire ?,,
the plug that come from the back has 3 wires:
-green
-purple/with white line- speed sensor wire
-red/ with wihte line
my dvd is playing but only in a backround,,if i want to acces ""dvd map error" i get,,
im working in a 2002 escalade
any help will be apreciate,,
bosanci28
05-15-08, 10:19 PM
fixed the video,,
red wire to ground!,work,all ther way
but where do i connect the speed sensor wire?
and maybe someone has the 2002 escalade cadilac wiring diagram,,
thanks
LadeOut
07-11-08, 09:35 PM
have a question for you, I have an 02 Escalade as well but how did you fit the double din radio into the 1.3 din spot, did you buy a new bezel (if so where did you purchase it) or did you shave out the surrounding area?
this question is for everyone to answer if you have done this, any info would be greatly appreciated.
mclovin68
12-18-08, 04:30 PM
u have to hook it to the sensor wire from ur transmission thats what my friend did to my escalade
Cliff8928
12-19-08, 01:20 AM
Nah, in a 02 escalade the wire is already there. The old Delco radios had VSS inputs for the SCV.
The VSS wire is in the factory harness. Connector C2 pin 16. It's the dark green / White wire.
CadillacSTS42005
12-20-08, 10:22 AM
cliff has it correct
answer to ladeout
you must buy and upgrade to an 03+ dash bezel
from there its a simple install so long as you buy the correct harness for your application
pcguy760
03-26-09, 11:14 PM
Ok I am not sure which harness you are talking about - the Radio Harness? There are two so which is C2?
