limoguy
05-11-08, 11:13 AM
I tryyed both door controls. Window goes down only.The window is on the track also. Would I be able to pull the window up by hand without destroying anything and leave it up? thanks:crybaby:
| View Full Version : passanger window not going up limoguy 05-11-08, 11:13 AM I tryyed both door controls. Window goes down only.The window is on the track also. Would I be able to pull the window up by hand without destroying anything and leave it up? thanks:crybaby: still_walkin 06-22-08, 07:43 AM sounds like your motor is going out mine does the same thing try rockauto.com for a new window motor carnut 06-22-08, 02:03 PM Power goes to the driver door master switch first so I would suspect that switch. If in fact, the glass in on the track you cannt pull it up. Try this, Key on, door switch held in the up position, bang the door panel down low towards the front. Sometimes the window motor binds in the down position. Banging on the door panel sometimes frees it up. If it goes up, buy a lottery ticket!! | |
