Cadillac Crest
05-09-08, 07:51 AM
Sometimes when I wake up in the morning, I find that the trunk of my 1994 cadillac deville concours is open. It shuts normally when I close it, the motor turns on and it seals itself. It has 137000 miles on it, what could it be????THanks
NickySantoro
05-09-08, 12:08 PM
Check your battery voltage. I've seen low voltage cause weird things on these cars, especially older ones like yours and mine.
Cadillac Crest
05-12-08, 12:23 AM
When should I check my battery voltage?
NickySantoro
05-12-08, 08:16 AM
I'd do it the next time the trunk opens itself. With the car off, check it with a VOM across the battery terminals. You might also verify that the terminals are clean and tight.
Cadillac Crest
05-24-08, 03:24 AM
hey, i woke up and my trunk was open again. I checked the voltage through the DIC and got 11.3. The cables on the battery are tight and clean, i didnt use a voltmeter because i was on my way to work.
NickySantoro
05-26-08, 07:39 AM
That 11.3 sounds low. You might want to confirm that with a VOM. What is the charging voltage? Age and condition of the battery? Is there a possibility of a parasitic drain caused by a glove box or trunk light not shutting off?
