View Full Version : crankshaft sensor location ?
ronsdeville
05-07-08, 09:06 PM
can someone tell me where the lower ( A ) crankshaft position sensor is located . I took off the splash guard and i think i see it above the oil filter on the radiator side of the engine. If this is it , it looks like you have to be double jointed to get to it.Do i need a tool to get the wire connection off and is the hold down stud 10mm . any and all help will be appreciated . thanks:hmm:
Submariner409
05-08-08, 09:16 AM
Late Northstar (post-00). Manual says to remove filter and filter adapter. You'll need new adapter O-rings and (if equipped) oil cooler line quick-connect fittings (manual says replace if opened). 10mm. Magic words. Hot oil.
Click on pic and scroll in.
Ranger
05-08-08, 11:30 AM
Replace both of them while you are there.
91parkave
05-08-08, 12:53 PM
you can just take the front engine mount off youll have enough room to get at it then. 6 15mm nuts will get the job done.
Ur7x
05-08-08, 06:57 PM
I've done this 4 or 5 times... remove the oil filter and adapter and thats all you need, its tight, and the connectors are a bear, but there is no need to remove the front mount.
