arnauts
05-06-08, 01:20 AM
Do I need to apply any gasket sealant to my replacement 425 valve cover gaskets? I got fed up with the rusty appearance, not to mention the catastrophic leaks. The replacements are Fel-Pro cork gaskets.
| View Full Version : Real quick valve cover question! arnauts 05-06-08, 01:20 AM Do I need to apply any gasket sealant to my replacement 425 valve cover gaskets? I got fed up with the rusty appearance, not to mention the catastrophic leaks. The replacements are Fel-Pro cork gaskets. fslay 05-06-08, 09:38 AM This is my opinion, but I recently replaced the valve cover gaskets on my 425, and as long as you take a good razor blade and remove all the old gasket material, it should seal fine. I made sure to go all the way around the top of the head with a razor blade, keeping it nice and level all the way around. Then, I wipe with a rag and feel for any remaining material. As long as it's clean, I don't see the need for anything but the gasket itself. arnauts 05-06-08, 11:07 PM Thanks very much! Looks like I've got some baked on gaskets to remove. | |
