: Escalade Rough Ride
05-04-08, 01:46 AM
I bought a 2004 Escalade with 40,000 miles 3 months ago and I feel every bump in the road. Can I check anything or adjust anything on my truck to make it ride softer. I think the previous owner did adjust the front supspension because the front of the truck sits alot lower than the back or if anybody has manufacture specs that I could set the truck back to.
05-05-08, 02:58 AM
do you have the wheels or aftermarket?
05-05-08, 10:59 PM
a front end alignment will fix that, tell them to put the torsion bars back to factory specs. When i purchased my truck the guy had the torsion bars adjusted so the front end was lower then the back. I have spindles on it now, and the front end is still a little lower but at least it's done right. The ride is still a little rough for my liking and i'm still looking to see what else can be causing it.
05-06-08, 12:44 AM
I am Running aftermarket wheels in the summer and stock in the winter.
05-06-08, 08:42 AM
If you are running 24's or 26's you will feel every bump after switching from your winter tires, I just did that and I sold both sets of 26's and one set of 24's, where I have to drive those sizes just do not work. :(
