View Full Version : service ride control
nomadgj
05-01-08, 12:58 AM
I have an 03 ext and I am getting this read out "sevice ride control" I think the air shock leveler is not working. Is there a fuse that might be out or what is most likely the problem??
cadillacroadside
05-01-08, 08:06 AM
one can never assume a "likely" problem when any given indicater comes on, if your level ride is not working yes it will set a code. do you hear the pump running? if so you could have a leak or open vent valve, is the truck sitting down in the rear without the pump working, then it could be electrical.
mard542
08-29-08, 08:51 AM
I read out service ride control could you please let me know what that means. Also I was hearing the pump runing, but now I don't hear the pump runing.
