View Full Version : tROUbLE COdES???
FRESH77015
04-29-08, 06:45 AM
Hi i have a 2002 Cadillac DHS I recently checked the obd on the car and have some current trouble codes that came up. I need help fixing these codes any help will be greatly appreciated =]
1. B3832 - Window Position Sensor Circuit
2. B0429 - Temperature Control #3 Rear Circuit Range/Performance
3. B1586 - Mirror Horiz. Pos Sensor-Out of Range/Open
carnut
04-30-08, 02:23 PM
Erase all codes, then pull the codes again after a couple of days. Could be just old codes because you make no mention of any problems.
FRESH77015
04-30-08, 07:00 PM
Oh sorry these are current codes my car has at the moment. Also I have the P1540 which is the refrigerant overpressure but the system pressure is just fine so i took it to a a/c tech/ auto electrician and told me the pressure switch behind the compressor might be faulty. That switch runs about $60 at the dealer he also mentioned that i might as well change the other sensor out since the freon is going to be discharged might as well change all possible faulty sensors... The over all price for these sensors are going to run at about $160 plus $140 hes going to charge me to do the job.. Am I getting a good deal???
carnut
04-30-08, 07:07 PM
The word "MIGHT" is mechanics jargon to allow him to replace all the sensors so he has no come back issue!
