View Full Version : I got codes....
big daddy deville
04-28-08, 02:11 PM
I have a PC0716 and PC0717 in history... I checked them about a year ago and just had one (can't remember which one, think it was 0716?) occasionally I get the service transmission soon warning when coming off of the interstate , but it continues to shift fine, no real problems... my question is now I get the other code, so is it actually the sensor, or could it be the connector or wiring?
P0716 - Input Speed Sensor Circuit Intermittent
P0717 - Input Speed Sensor Circuit Low Input
submariner409
04-28-08, 02:55 PM
If they're both history you might try clearing them and, when you get the "service transmission" warning, see if that's when they come back. The "circuit" designator sounds like wiring or a damp connector from here..........speed sensors are in the wheel bearing capsules, and there's a transmission input sensor also, so you might have some wiring checks to do.
Factory Service Manual? www.alldatadiy.com subscription?
big daddy deville
05-01-08, 02:08 PM
I have been clearing the codes for about a year, I just now started getting the PO717...and so far it was only once. the sensor is in the wheel bearing? I thought the ISS was a 20.00 part burried 2000.00 deep in the tranny? so as long as there are no real shifting issues, I should be fine?
submariner409
05-01-08, 04:21 PM
You're correct, the vehicle and input speed sensors are transmission parts......I was going on checking electrical connectors to speed sensors first before tearing into the transmission......
There is a Vehicle Speed Sensor on top of the transmission nose just under the front of the right cylinder head. Looks like there's a brace to the head which must be removed, but the sensor slides out of a tube and retainer bolt affair. The rate manual says it's a $26 part and 0.5 hour to replace, on a lift.
The Input Speed Sensor is in fact buried inside the transmission....... and that's about an 11 hour rate.
Went through my Alldata subscription for my car: the transmission systems and electrical specs are mind-boggling........
big daddy deville
05-02-08, 09:45 AM
Thanks, I will check it al out....
