assdragginsdime
04-27-08, 02:23 PM
Hi guys, i have a 70 coupe deville. I picked up the car about a month ago. I drve it home, about a 2 hr drive, and the whole way back if i put the pedal to the floor, it would bog out. i could get it up to 75 no problem, but if i wanted to open it up, it just bogged out
so i figured id rplace the carb. after reading alot of threads on this forum i had read that keeping the quadrajet was the best option. So i managed to find one on ebay. The acution said it was for a 70. But when i got it, i ran the numbers and said it was off a 72. Now they were basically identical except for a few things.
1, the fuel bung is a different size. Not a big deal, i just replaced the fitting, and used a small length of rubber hose.
2, On the passenger side front of the carburetor, On my original 70 carb it had a small pin with a spring sticking out the top. The new 72 unit does not.
Old:
http://img.photobucket.com/albums/v179/sjm98126/IMG_0565.jpg
New:
http://img.photobucket.com/albums/v179/sjm98126/IMG_0574.jpg
Now i put the carb on the car. And it starts up, idles VERY rough, and backfires.. I did not have any of the vacuum hoses hooke up. I am not sure where they are supposed to go. I found a diagram on another thread on here, but there were a few extra parts in the diagram, that i do not have on my car.
Now, i really dont have any experiece with carbs. so this is kinda new to me.
A guy i work with told me that the heat sensitive choke spring should allow the primaries to stay wide open at temp. weather its at idle or not.
What im confused on, is i read something on another site. believe it was a corvette site, They siad that the secondaries begin opening at 50% or so of the primaries being open? So if the chokespring keeps the primaries Wide open, how does that work?
The car right now barely runs, it idles real rough, and has NO power. it rev's VERY slow, and probly doesnt get past 2500 or so. Giving it full throttle makes it backfire and stall. i managed to get the car to creep up my driveway. But i had it towed to my shop, which has a SMALL incline going into the bay door, and it wouldnt budge.
Im trying to figure out where i should start, in setting up this carb to work on my car. If in fact it will work at all.
the old carb number was 7040230 And the new carb number is 7042234.
The choke pulloff on the new carb is hooked up a little different than it was on the old one. I honestly dont remember where it went before, i was stupid, forgot to lable things, and just pulled it all off.
But heres a pic of the old choke pulloff, and how the new one is routed.
Notice the direction that the vacuum port is facing.
New:
http://img.photobucket.com/albums/v179/sjm98126/IMG_0571.jpg
Now Heres some pics of the vacuum hoses and what not. If anyone can give me some insight as to how i need to hook everything back up, it would be greatly appreciated.
Front of the carb:
http://img.photobucket.com/albums/v179/sjm98126/IMG_0577.jpg
back of the carb:
http://img.photobucket.com/albums/v179/sjm98126/IMG_0578.jpg
http://img.photobucket.com/albums/v179/sjm98126/IMG_0576.jpg
And this hose
http://img.photobucket.com/albums/v179/sjm98126/IMG_0579.jpg
which runs into this:
http://img.photobucket.com/albums/v179/sjm98126/IMG_0580.jpg
And then the vacum advance on the distributor.
Id appreciate any help anyone can give me.
Old:
New:
New:
Front of the carb:
back of the carb:
And this hose
