: Weird RPM increase?
gtm245
05-28-04, 12:10 PM
I know this probably has nothing to do with oil lubrication at all but I thought I'd throw this out there as I'm stumped on what it is. Ever since I bought my car a few months ago the car has idled at exactly 850 RPM when in P or N and idled at exactly 750 RPM when in gear. About a week ago I got up in the morning and went outside to start my car. Ever since that morning it has idled at 1400 RPM in P or N and idled at about 1000 - 1050 in gear. Is there any good explaination for this? Do I need a good tune-up like plugs, wires, ect... or is it something else? I just have no idea why my idle all of a sudden went up like 600 RPM. :hmm:
The car is a good ole 96 Chrysler LHS with the 3.5L 24V V6. Hope this helps in some way. Oh and it has 153,000 miles on it. :rolleyes:
S10xGN
05-28-04, 03:51 PM
Sounds like a vacuum leak. You probably lost a vacuum hose (rotted or blown off).
gtm245
05-28-04, 06:56 PM
Wouldn't a vacuum leak cause a surge when you put it in gear? Like the car wants to race off without you touching the gas?
Dead Sled
05-28-04, 10:45 PM
clean the throttle body that will help
although a drity throttle body will cause low idle and stalling
err too many years ago since i was a chrysler tech
Stoneage_Caddy
05-29-04, 11:12 AM
saw similar issues in SR20 cars , there was a idle air conrtoll valve that would get plugged up or go bad . perhaps the 3.5 has a idle air valve somewhere ?
S10xGN
05-29-04, 11:48 AM
Why would it? I'd never seen that happen before...
If the problem occured suddenly like he stated, I'm still banking on a vacuum hose. I've had throttle bodies and IAC motors get dirty before and have never seen a "sudden" problematic change.
gtm245
05-29-04, 04:56 PM
Well it turned out to be the upper intake manifold gasket was leaking and letting in air. I put on a new Fel-Pro gasket today and all is well again. :thumbsup:
Dead Sled
05-29-04, 05:03 PM
glad to see you fixed it, I should have known better
