: SRX Nav Mute Pin Out
Tee
04-18-08, 11:30 AM
I have a 2004 SRX with Navigation (No XM) I am installing a Motorola HF 850 Bluetooth handsfree car kit. I need to hook into the "mute" if the nav unit has that wire in the plug. Anyone know which (if any) wire that will be.
Thanks
CadillacSTS42005
04-18-08, 11:52 AM
not mute wire at the radio
only mute is at the amp
Tee
04-18-08, 12:41 PM
Thanks for quick reply. Where is the amp located and do you have the color code of the "mute" wire or pin location????????????????????
cadmanchris
04-18-08, 11:01 PM
I'm not sure, but I think the mute function works via Class 2.
CadillacSTS42005
04-19-08, 09:38 AM
egh by bad
i assumed the nav in that car worked the same as in a dev sev
there is no mute wire period
Tee
04-19-08, 09:59 PM
egh by bad
Thanks. I guess it will be no mute..............................
