sticckz
04-18-08, 12:23 AM
Can anyone briefly explain to me the positives
as well as the negatives to putting the V exhaust on a 3.6
And advice, comments from those cts owners, who have done this before
A few questions i have.
-Will the 3.6 sound similar to the V with the exhaust?
-Will i loose hp or torque?
-Can this be bad to my engine?
I'd appreciate any replies!..thanks in advance
CaddiLackin
04-18-08, 01:00 AM
Sure as hell wont sound like a V, however it will sound better than stock.
I am sure GM expended both alot of time and money to tune both the CTS and the CTS V exhaust systems for the best sound and performance for each engine. While I have no doubt the V exhaust will flow better than the non V will, back pressure or a lack of it is not always the best thing for performance.
Sometimes losing backpressure hurts performance sometimes it helps. I wouldn't risk my dollars betting on an exhaust designed and tuned for a much larger engine with a very different flow requirement.
If you want to get a gain in HP from your CTS imo you should look at a system tuned to the engine in your car.I haven't researched the subject at all but there have to be several companies making an exhaust system designed and tuned for your car. There are many knowledgable people here that will hopefully chime in with some suggestions on what exhaust system you should purchase.
.02
tommy compton
04-18-08, 01:56 AM
simply put, you will lose low end torque with the v" exhaust. borla, corsa or magna flow are the way to go.
TotalEclipse31
04-18-08, 10:16 AM
While everyone is on the subject, I want to get an exhaust on my car, but what is the pros and cons of just having my local muffler shop put 2 flowmaster mufflers, remove rezignators (spelling?), and throw on some stainless tips VS buying a full exhaust sytem?
-=AlexXx=-
04-18-08, 11:33 AM
Totaleclipse thats mostly what i wanted to do.
sticckz
04-18-08, 05:30 PM
will adding a magnaflow muffler rather
than a whole new pricey exhaust..help my hp?
or will it cost me hp as well?
The shop I went to said that the magnaflow mufflers will add a few hp but not as much as a full catback exhaust would. I'm still undecided myself as to what I wanna do !
TotalEclipse31
04-18-08, 06:06 PM
GRRRr....Cause its really a difference of a couple hundred dollars. Need to find out how much of a HP difference there really should b. Ya know?
se7enone8ight
04-18-08, 07:18 PM
i mean of course ur shop would tell u that ... means more money for them but in all honesty the cts is not a tuner car, i know everyone wants to go faster (including me) .. there are plenty of ways to gain #'s effectively, try replacing ur resonator with an xpipe and then go with a hi-flo cat, pete raimondi was actually lookin to get rid of a set, try a search im sure u"ll find it and i believe it was an increase btwn 15-20 whp OR u could pick up a v exhaust and throw an xpipe on there and replace the mufflers ... price it out and go from there
concorso
04-18-08, 08:11 PM
GRRRr....Cause its really a difference of a couple hundred dollars. Need to find out how much of a HP difference there really should b. Ya know?There are a couple big threads if you search back about a year. They include a couple different combinations and dyno results.
HEre, I just found these for ya...not the ones I originally read a few months ago, but theyre a start.
http://www.cadillacforums.com/forums/cadillac-cts-forum-2003-through-2007/110619-trying-make-sense-dyno-numbers-my.html
http://www.cadillacforums.com/forums/cadillac-cts-forum-2003-through-2007/108465-v-exhaust-x-pipe-magnaflow-mufflers.html
http://www.cadillacforums.com/forums/cadillac-cts-forum-2003-through-2007/58398-dyno-results-3-6-w-v.html
Look for posts by these names: pjohnesq, sdmarineguy, robertcts, odysseus...all of these guys did exhuast work that was dyno'd...there may have been others too
