: towing a 27' boat for 4 hours???
04-17-08, 11:50 AM
I have a ??
I am planning on towing a 27' boat (7000-ish lb) for 4 hours any precaution.
my engine shouldn't reach what temp.
and on the highway should i turn off the towing or should i leave it on.
Thanks for the help.
04-17-08, 12:02 PM
I tow a trailer that is 26 ft and weighs over 7k loaded, and many times it for 6-7 hours, it is in the winter. I use the tow mode for the mountains but on flat highways I use it in the regular mode. I have towed in the summer and never really had any temp issues, it was like I was not even towing looking at the gauges, of course that is not true for the gas gauge. :(
04-17-08, 03:42 PM
would towing in regular mode benefit engine, gas, etc VS the hauling mode?
04-17-08, 04:40 PM
Not really, when you are towing heavy weight your gas mileage will be pretty poor, not as bad on flat ground, but still pretty bad.
05-13-08, 12:18 PM
Engine temp is probably not something to worry about, but transmission temp is. At those weights, you will definitely be pushing 200 degrees more than once. I think you have to be careful if you sustain transmission temps (check your tranny temp gauge in the digital readout - that should ALWAYS be on when you are towing, look at nothing else on the computer) over 207 degrees for a period of time.
05-14-08, 09:07 AM
The trans has synthetic fluid in it, you should have no problems even if you get about 250 degrees.
05-14-08, 06:08 PM
Good to know!! Whew!
