: 2004 front air doesn't blow
04-14-08, 11:56 PM
This is my first time in the forum. Three days ago the front air of my 2004 ESV stopped blowing air but the rear is still working fine, is this to hard to fix or there is something I can check before to go to the dealer for an inspection. Any help will be appreciated
Thank you very much in advance for your response.
04-15-08, 07:10 PM
check the blower motor and the blower resistor
under the pass side of the dash (glovebox area) -- there is a black hush panel you'll have to remove but it isn't a big deal..
more than likely it is the blower itself if it never comes on at all. try tapping it a few times and see if it comes on...
04-15-08, 07:25 PM
Did you do anything before this happened? Install or uninstall anything electronic in the vehicle? The front and rear blowers are on separate fuses IIRC. You may check the integrity of the blower motor's fuse.
04-18-08, 11:53 PM
The first response is right on. Try tapping the black blower cover under the glove compartment. It should come back on.
04-19-08, 03:52 PM
No update? :hmm:
